Re: RING GEAR TOOTH REPAIR???
[Re: Labratt]
#1109067
11/08/11 12:41 AM
11/08/11 12:41 AM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
I DO NOT RECOMEND THIS Back in the day I welded up a tooth just like that and filed it to shape, worked fine for me then....
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: Labratt]
#1109074
11/08/11 03:17 PM
11/08/11 03:17 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thanks,Carl! Now..if I can find somebody in the Detroit area to do it,I'll be all set! ANY SUGGESTIONS on who can fix this?
I can fix that Randy... I've done a FEW starter ring gears
[Re: Labratt]
#1109077
11/08/11 08:15 PM
11/08/11 08:15 PM
MR_P_BODY
Mike...you're hired! Hope you're enjoying the "North Country"! Fred,I noticed that too! Looks like the starter teeth were only engaged 50% of the ring gear tooth depth. I've got a new starter on the shelf..I'll just use that when the X gets put back together! Thanks for taking a look! Randy B.
I'm down here for a couple of days... closing on a re-morgage... have you thought about coming up there to hunt
[Re: Super Scamp]
#1109079
11/08/11 09:36 PM
11/08/11 09:36 PM
MR_P_BODY
Like your really hunting
That's a 15 min. repair for a welder.
Actually doing a lot of hunting... got a real nice 5 point(was a 6, but it broke a point) ... big body
[Re: Evil Spirit]
#1109081
11/08/11 10:16 PM
11/08/11 10:16 PM
MR_P_BODY
In some places it looks like the gear is bottomed out, which won't let the bendix push the gear out fully. The paint is wiped off in the bottom of the teeth, but only 1/2 way across the face. On a Chevy you fix that with shims - I don't know how you would fix that on a Mopar, other than just trying to wiggle the starter away from the engine while tightening.
For all I know it could be the whole ring is welded on a little off center... .020 is allowable
[Re: W.I.N. Racing]
#1109082
11/08/11 11:52 PM
11/08/11 11:52 PM
W.I.N. Racing
Byron, NY
Because when I typicaly do recomend this type of fix ...it bites me in the A$$...Thats why I followed it up with it worked for me.
