RING GEAR TOOTH REPAIR??? #1109066
11/08/11 12:20 AM
11/08/11 12:20 AM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
As you can see on the picture...one tooth was damaged by a sticking starter bendix. It's pretty much down to nothing left! My question is...can this be weld-repaired and re-ground to match the other teeth? I wouldn't think I'd have to replace the ring gear...just repair this one tooth! Please give me your opinions! Thanks in advance,fella's! Randy B.
Re: RING GEAR TOOTH REPAIR??? [Re: Labratt] #1109067
11/08/11 12:41 AM
11/08/11 12:41 AM
Byron, NY
W.I.N. Racing Offline
Byron, NY
I DO NOT RECOMEND THIS Back in the day I welded up a tooth just like that and filed it to shape, worked fine for me then....
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: RING GEAR TOOTH REPAIR??? [Re: W.I.N. Racing] #1109068
11/08/11 01:41 AM
11/08/11 01:41 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Bill,if it worked for you..why don't you recommend doing it? Did it not last?
Re: RING GEAR TOOTH REPAIR??? [Re: Labratt] #1109069
11/08/11 01:42 AM
11/08/11 01:42 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
A good tig welder can fix that reasonably easy. Build up weld, grind to shape - done like dinner, as long as you fixed the problem that broke it the first time.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: RING GEAR TOOTH REPAIR??? [Re: Evil Spirit] #1109070
11/08/11 02:59 AM
11/08/11 02:59 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Willie,that's what I was thinking! The cause of the problem was a faulty ignition switch..which was sticking in the START mode..just enough to break off ONE TOOTH on the ring gear! Needless to say,I replaced the switch a while back!
Re: RING GEAR TOOTH REPAIR??? [Re: Labratt] #1109071
11/08/11 03:32 AM
11/08/11 03:32 AM
Tennessee
727builder Offline
727builder  Offline
Tennessee
I wouldn't hesitate for a second to weld it up and re-shape it back. Weld will be stronger than the rest of the teeth on it.
Re: RING GEAR TOOTH REPAIR??? [Re: 727builder] #1109072
11/08/11 02:15 PM
11/08/11 02:15 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks,Carl! Now..if I can find somebody in the Detroit area to do it,I'll be all set! ANY SUGGESTIONS on who can fix this?
Re: RING GEAR TOOTH REPAIR??? [Re: Labratt] #1109073
11/08/11 02:33 PM
11/08/11 02:33 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
when i brought my converter in to a local trans shop API here in toronto for a freshen up, they noticed a missing tooth and welded it up and reshaped it, been working fine for about 4-5 years now. funny thing is i knew it was broken but it never caused any problems so i wasn't even considering fixing it when i brought the converter in, but vic (the owner of API) wouldn't let it go out without fixing it and didn't even charge me for it. it should be a fairly easy fix for any place that services converters.
Re: RING GEAR TOOTH REPAIR??? [Re: Labratt] #1109074
11/08/11 03:17 PM
11/08/11 03:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I can fix that Randy... I've done a FEW starter ring gears
Re: RING GEAR TOOTH REPAIR??? [Re: Labratt] #1109075
11/08/11 03:30 PM
11/08/11 03:30 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
I think you also have issues with contact depth of the teeth on the gear.
home of the
Sox and Martin Hemi Duster
Re: RING GEAR TOOTH REPAIR??? [Re: HEMIFRED] #1109076
11/08/11 05:07 PM
11/08/11 05:07 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Mike...you're hired! Hope you're enjoying the "North Country"! Fred,I noticed that too! Looks like the starter teeth were only engaged 50% of the ring gear tooth depth. I've got a new starter on the shelf..I'll just use that when the X gets put back together! Thanks for taking a look! Randy B.
Re: RING GEAR TOOTH REPAIR??? [Re: Labratt] #1109077
11/08/11 08:15 PM
11/08/11 08:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm down here for a couple of days... closing on a
re-morgage... have you thought about coming up there
to hunt
Re: RING GEAR TOOTH REPAIR??? [Re: MR_P_BODY] #1109078
11/08/11 09:17 PM
11/08/11 09:17 PM
Super Scamp Offline
Super Scamp  Offline
to hunt
Like your really hunting
That's a 15 min. repair for a welder.
Just One Man's Opinion Mopar Mafia Racing
Re: RING GEAR TOOTH REPAIR??? [Re: Super Scamp] #1109079
11/08/11 09:36 PM
11/08/11 09:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
to hunt
Actually doing a lot of hunting... got a real nice
5 point(was a 6, but it broke a point) ... big body
Re: RING GEAR TOOTH REPAIR??? [Re: Labratt] #1109080
11/08/11 10:03 PM
11/08/11 10:03 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
In some places it looks like the gear is bottomed out, which won't let the bendix push the gear out fully. The paint is wiped off in the bottom of the teeth, but only 1/2 way across the face. On a Chevy you fix that with shims - I don't know how you would fix that on a Mopar, other than just trying to wiggle the starter away from the engine while tightening.
Re: RING GEAR TOOTH REPAIR??? [Re: Evil Spirit] #1109081
11/08/11 10:16 PM
11/08/11 10:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
For all I know it could be the whole ring is welded
on a little off center... .020 is allowable
Re: RING GEAR TOOTH REPAIR??? [Re: W.I.N. Racing] #1109082
11/08/11 11:52 PM
11/08/11 11:52 PM
Byron, NY
Byron, NY
Because when I typicaly do recomend this type of fix ...it bites me in the A$$...Thats why I followed it up with it worked for me.
'60 Willys CJ5
Re: RING GEAR TOOTH REPAIR??? [Re: W.I.N. Racing] #1109083
11/09/11 12:28 AM
11/09/11 12:28 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Bill..thanks for the clarification!...ya had me worried there! Raff...PM sent!
