hard starting when warm #1109029
11/07/11 10:58 PM
11/07/11 10:58 PM
Stouffville Ontario
7434 mopars Offline OP
Stouffville Ontario
After driving my 70 challenger 440-6 pack, I shut it off and when I tried to start it again when the engine was warm, it wouldn't start. When I tried to start it when warm, it would just crank over and over.
I had to wait till it cooled off before it would start. Any suggestions would be apprecited.
Re: hard starting when warm [Re: 7434 mopars] #1109030
11/07/11 11:22 PM
11/07/11 11:22 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
When my dad's car had this problem, we searched for vapor lock etc., nope.
It turned out the reluctor gap in the MP distributor was too wide. We set it to spec .008" and it was fine after that.
Re: hard starting when warm [Re: Exit1965] #1109031
11/07/11 11:25 PM
11/07/11 11:25 PM
Northern Virginia
Moparmaniacc Offline
Northern Virginia
Starting ether will get anything started as long as the ignition still works!
Re: hard starting when warm [Re: Moparmaniacc] #1109032
11/08/11 12:57 AM
11/08/11 12:57 AM
X2. They say it's hard on the eng but dont remem why but I use it on occaision but try to keep it to a minimum
Re: hard starting when warm [Re: Exit1965] #1109033
11/08/11 01:01 AM
11/08/11 01:01 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
I had this happen once, too.
It's Swifty! Swifty, you toad sucker!
Re: hard starting when warm [Re: zrxkawboy] #1109034
11/08/11 01:10 AM
11/08/11 01:10 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Do you have a vapor separator? I had this problem with mine and it turned out the return orifice of the vapor separator was too large. After a hot shut-down I guess it was returning enough fuel through the return hose to not supply enough to restart the engine until it cooled. I put a hose clamp on the rubber part of the return line right after the separator and clamped it down hard enough to block off the return completely and it fired right up and ran like a champ. I've heard from others that this can be a problem with repro vapor separators.
As did I. For some reason the reluctor gap only affected hot restarts.
Re: hard starting when warm [Re: zrxkawboy] #1109035
11/08/11 01:11 AM
11/08/11 01:11 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
If the gap is too wide, the ECU box will not fire..
Also the gap is even more critical of the air temperature is on the cold side, harder for the magnet to close..
Just my $0.02..
