440 spark plug wire clearance issue #1107683
11/05/11 07:51 PM
11/05/11 07:51 PM
BC Canada
62440 Offline OP
62440  Offline OP
BC Canada
I just started putting plug wires on my 440 and noticed #5 and 6 both are really tight to my Hedman headers, like touching. I'm using 7 mm NKG Blue high temp silicone 250* Celsius + Not sure what that is in Fahrenheit, but I suspect it is less than those headers will get. They are angled plug wires. I'm using those fiberglass socks as well but they wouldn't fit on #5 and 6 either. I kind doubt they would help anyways. I'm looking for any suggestions. I was thinking maybe a straight plug connection. Last choice I guess is a BFH
Re: 440 spark plug wire clearance issue [Re: 62440] #1107684
11/05/11 08:37 PM
11/05/11 08:37 PM
If that looks like it would work I would go ahead & get 2 of em
Re: 440 spark plug wire clearance issue [Re: 62440] #1107685
11/05/11 08:41 PM
11/05/11 08:41 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i use straight plug but bendable on all the plugs and fiberglass socks on those same 2 plugs.
Re: 440 spark plug wire clearance issue [Re: mikemee1331] #1107686
11/05/11 09:28 PM
11/05/11 09:28 PM
IN
ahy Offline
ahy  Offline
IN
I used MSD bendable boot wires - different setup but similar problem. They worked great.
Re: 440 spark plug wire clearance issue [Re: ahy] #1107687
11/05/11 11:03 PM
11/05/11 11:03 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i got the same setup,i just use 90,s no prob.
Re: 440 spark plug wire clearance issue [Re: bonefish] #1107688
11/06/11 01:03 AM
11/06/11 01:03 AM
BC Canada
62440 Offline OP
62440  Offline OP
BC Canada
Do all you guys have Hedman headers and what brand wire are you using ??? I'm just wondering why mine are so tight. I mean Zero clearance.
Re: 440 spark plug wire clearance issue [Re: 62440] #1107689
11/06/11 08:53 AM
11/06/11 08:53 AM
STL
cdstl Offline
cdstl  Offline
STL
Double the Celsius temp., subtract 10 percent and add 32 = Fahrenheit temperature.
250 times 2 = 500
500-50=450
450+32= 482 degrees Fahrenheit
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: 440 spark plug wire clearance issue [Re: 62440] #1107690
11/06/11 09:00 AM
11/06/11 09:00 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
yes, i have Hedman and power steering so imagine how tight it is. i have used both Accel and MSD wires with straight boots. i have no preference in brand to speak of except Accel is yellow and matches my car but i always ohm the wires before and after i cut and crimp.
Re: 440 spark plug wire clearance issue [Re: mikemee1331] #1107691
11/06/11 10:21 AM
11/06/11 10:21 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
what heads do you have?
Re: 440 spark plug wire clearance issue [Re: ahy] #1107692
11/06/11 10:40 AM
11/06/11 10:40 AM
wi.
W
wrapper Offline
wrapper  Offline
W
wi.
same here used msd's..........no problemo
Re: 440 spark plug wire clearance issue [Re: cdstl] #1107693
11/06/11 10:42 AM
11/06/11 10:42 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
A little simpler I think: (C x 1.8)+32=F
Re: 440 spark plug wire clearance issue [Re: bonefish] #1107694
11/06/11 11:18 AM
11/06/11 11:18 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
MP 906's
Re: 440 spark plug wire clearance issue [Re: mikemee1331] #1107695
11/06/11 11:23 AM
11/06/11 11:23 AM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
If you post some pics up, I'm sure can can help with what boots might work better. I've got hundreds of pics of different header/boot combo's. Just not sure on the type of some of the headers. I can send you some boots if you decide you need some higher temp. Don't hammer on your headers if all it will take is a different boot.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: 440 spark plug wire clearance issue [Re: RapidRobert] #1107696
11/06/11 11:25 AM
11/06/11 11:25 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I use the MSD 8mm black set. They have adjustable boots. http://www.summitracing.com/parts/MSD-5531/
they work well for me. I have the insolators on 5&6 as well
Coming soon!!!!
Re: 440 spark plug wire clearance issue [Re: BSB67] #1107697
11/06/11 12:40 PM
11/06/11 12:40 PM
STL
cdstl Offline
cdstl  Offline
STL
I'll remember that one. I am converting temps all of the time and the other way is quicker for my old brain.
Re: 440 spark plug wire clearance issue [Re: cdstl] #1107698
11/06/11 02:54 PM
11/06/11 02:54 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
i actually went with DOUG'S headers,absolutely no problems,plenty of clearance,change plugs in 10min. but as said go with whatever boot fits,hammering headers a last resort
Re: 440 spark plug wire clearance issue [Re: 62440] #1107699
11/06/11 03:02 PM
11/06/11 03:02 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
I have Hedmans on a 440 and I run Taylor's 45 degree wires. They don't touch but they are close.
Re: 440 spark plug wire clearance issue [Re: Pacnorthcuda] #1107700
11/06/11 07:54 PM
11/06/11 07:54 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
If the fiberglass boot sock is actually touching the header it won't last long...It'll burn and turn white...Then it actually holds the heat in worst than if you had nothing around it...
Re: 440 spark plug wire clearance issue [Re: screamindriver] #1107701
11/07/11 02:11 AM
11/07/11 02:11 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I used Taylors on my old 440 and the set had 2 straight ends and the rest were 90's. The set worked great with plenty of room and I had Hedman 1-3/4 headers on it. Ron
Re: 440 spark plug wire clearance issue [Re: 62440] #1107702
11/07/11 02:51 AM
11/07/11 02:51 AM
Dexter, Michigan
copper67440 Offline
mopar addict
copper67440  Offline
mopar addict
Dexter, Michigan
Talk to Rick sunroofGTX. Get a set of custom Firecore wires. He made a set for me 67 Coronet wth 383 and Hooker Super Comp headers stock heads and the wires fit perfectly.
http://www.customwiresets.com/
