tie-rod sleeve clamp #1107603
11/05/11 03:30 PM
11/05/11 03:30 PM
Toronto, Ont, Canada
boydsdodge Offline OP
Can you buy tie-rod sleeve clamps separate or only with sleeve?
I noticed that on my new Moog sleeves that one on one side the clamps have bottomed out no clamping force remaining
Re: tie-rod sleeve clamp [Re: boydsdodge] #1107604
11/05/11 05:44 PM
11/05/11 05:44 PM
You could put some shim stock inside the clamp ID to gain some seperation between the 2 ends
Re: tie-rod sleeve clamp [Re: RapidRobert] #1107605
11/06/11 09:17 PM
11/06/11 09:17 PM
Fixed it, just took 3/16ths off each side.
Works great.
