Do all 72 Charger 400s have starter relay? Mine Don't
#1106990
11/04/11 08:20 AM
11/04/11 08:20 AM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
We are still having sporadic starting issues. But the biggest problem is that there is no starter relay. It shows up in the wiring diagrams, but appears optional for 60A alternator cars. That doesn't make sense
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
Re: Do all 72 Charger 400s have starter relay? Mine Don't
[Re: MRHWS]
#1106994
11/04/11 02:28 PM
11/04/11 02:28 PM
70Coronet500Vert
St Charles MO
No neutral safety switch. Car definitely been rewired.
[Re: 70Coronet500Vert]
#1106995
11/04/11 04:22 PM
11/04/11 04:22 PM
Posts: 75,062 U.S.S.A.
JohnRR
U.S.S.A.
#1106997
11/05/11 08:15 AM
11/05/11 08:15 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
The starter relay was there to protect those wires under the dash - to keep from running the high amperage necessary for the starter solenoid through the bulkhead, switch, wiring, etc.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Evil Spirit]
#1106998
11/05/11 11:06 AM
11/05/11 11:06 AM
RapidRobert
If it was a race/stock car and they ran a wire from the starter batt stud in to a momentary contact switch and out to the starter small solenoid stud it'd work but I dont think that's the case here. I had harness probs and I finally just bought a good used complete underdash harness from a good guy (Steve Remington) on FABO. I finally realized the time to sort it was a waste and you're in a worse spot with burnt/hacked stuff. Good luck w it. PS What is LMAO ? Only acronym I never used on here EDIT & that in/out would not be thru the bulkhead but 2 seperate firewall holes/wires
