motor plate or solid mount #1106712
11/03/11 06:57 PM
11/03/11 06:57 PM
southwest pa
bodyworks racing Offline OP
southwest pa
wouyld like some input 11 sec b body weights 3150 race only. right now i have poly lock mounts and shumacher torque strap.the header is hitting the right shock tower on launch and i bent the torque strap car 60 ft is 1.54 runs 11.30,s solid mounts would be easier but? before i
68 ROADRUNNER 440 HORSE POWER IS HOW FAST YOU HIT THE WALL TORQUE IS HOW FAR YOU TAKE THE WALL WITH YOU
Re: motor plate or solid mount [Re: bodyworks racing] #1106713
11/03/11 07:57 PM
11/03/11 07:57 PM
Penna
70satelliteguy Offline
Penna
When our 70 B Body was running low 11's we had solid motor mounts and had no trouble with the headers hitting the shock towers. We also 60 ft. in the 1.50's at the time. that would seem to be the easy way to go. Running a motor plate is more involved with the water pump and 2 sets of gaskets and shimming the alternator and fan if you are running these.
MIke
Re: motor plate or solid mount [Re: 70satelliteguy] #1106714
11/03/11 10:07 PM
11/03/11 10:07 PM
southwest pa
southwest pa
thanks for the reply mike. i am looking for a fix to run next season after that the motor comes out and the new stroker motor gos in with plates. hopefuly it will live thru the year!
Re: motor plate or solid mount [Re: bodyworks racing] #1106715
11/03/11 10:48 PM
11/03/11 10:48 PM
Saskatchewan, Canada
barracudabob Offline
When my car did that, the motor mount on the passenger side was pooched. It wasn't torn, it just allowed a lot of movement. A new mount, and no more hitting the shock tower. This was on a '66 Satellite.
Re: motor plate or solid mount [Re: barracudabob] #1106716
11/04/11 01:59 AM
11/04/11 01:59 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My car is a street car so I use just a solid mount on the drivers side and it works good without much vibration. I just use the chain as backup just in case. Ron
Re: motor plate or solid mount [Re: 383man] #1106717
11/04/11 07:44 AM
11/04/11 07:44 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Solids are nice if your running stockish accessories. I prefer a plate because its easier to get the engine in and out and does not come anywhere near the headers. The Schumacher stuff is over priced junk.
Re: motor plate or solid mount [Re: Dragula] #1106718
11/04/11 08:53 AM
11/04/11 08:53 AM
an8sec70cuda Offline
I say put a plate in it now and be done w/ it. Much easier to R&R the engine and real nice to mount stuff on. Don't use gaskets for the water pump, just use silicone.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: motor plate or solid mount [Re: an8sec70cuda] #1106719
11/04/11 09:47 AM
11/04/11 09:47 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
if he puts a plate in how will that effect the alt mount?
Re: motor plate or solid mount [Re: bonefish] #1106720
11/04/11 09:58 AM
11/04/11 09:58 AM
He'll have to get a low mount kit. I think he was asking about going to an electric water pump a week or 2 ago, so belt/pulley alignment won't be an issue.
CHIP
Re: motor plate or solid mount [Re: an8sec70cuda] #1106721
11/04/11 10:16 AM
11/04/11 10:16 AM
southwest pa
southwest pa
i did put the elecric pump and low mount alt on already im thinking maybe just bite the bullit and do the plate ok next question who"s plate was not impresed by competion engeneering or summit and jegs.mancini however has one made from t-6 3/8 thick cut on a water jet anybody run one? thanks for the replys 383 man are you going to hagerstown?
Re: motor plate or solid mount [Re: bodyworks racing] #1106722
11/04/11 10:17 AM
11/04/11 10:17 AM
tboomer Online work
tboomer  Online Work
Maybe NHRAmark will chime in...They make a nice motor plate!
Re: motor plate or solid mount [Re: bodyworks racing] #1106723
11/04/11 10:22 AM
11/04/11 10:22 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
did you use the mopar alt or did you have to get a special alt.?
Re: motor plate or solid mount [Re: bodyworks racing] #1106724
11/04/11 10:34 AM
11/04/11 10:34 AM
I just use the Comp Engineering plates on mine. No need for the thicker plates in my opinion. I like the fact that the CE plates are one big sheet w/ no holes in it so you can cut it to fit how you want it and can mount stuff all over it.
CHIP
Re: motor plate or solid mount [Re: an8sec70cuda] #1106725
11/04/11 10:41 AM
11/04/11 10:41 AM
New Jersey
Craig Offline
Craig  Offline
New Jersey
Supposedly, mounts cost power compared to a plate due to cylinder wall flex and reduced ring seal. Not sure what power levels this would begin at though.
67 Dart, 426 Hemi, 9.23/145mph, 3400lbs, footbraked, owned since 1982
Re: motor plate or solid mount [Re: bodyworks racing] #1106726
11/04/11 12:17 PM
11/04/11 12:17 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
We do. Check us out at www.aeicnc.com
We've made plates for a lot of guys here. This is a 3/8" plate we made for a big block Mopar. You can't see a lot of the plate itself, but as you can see, you can mount everything you need on it.
All the engine mounting holes are in it, you just bolt it up and drop it in.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: motor plate or solid mount [Re: nhramark] #1106727
11/04/11 12:33 PM
11/04/11 12:33 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
Well that pic was too big, I'll fix it later. But here is a small block plate we made.
Re: motor plate or solid mount [Re: nhramark] #1106728
11/04/11 12:36 PM
11/04/11 12:36 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
And a Gen3 Hemi 3/8" plate we made for another member here..... you get the idea.
Re: motor plate or solid mount [Re: bonefish] #1106729
11/04/11 01:51 PM
11/04/11 01:51 PM
southwest pa
southwest pa
i used a denso alt 55 amp and the low mount came from mancini
Re: motor plate or solid mount [Re: nhramark] #1106730
11/04/11 01:53 PM
11/04/11 01:53 PM
southwest pa
southwest pa
very nice work mark i saved the web site so i can contact when im ready thanks
Re: motor plate or solid mount [Re: bodyworks racing] #1106731
11/04/11 02:11 PM
11/04/11 02:11 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
The mancini one is Andy F's ...?
