Re: throttle brackets
[Re: duspan]
#1106554
11/03/11 01:05 PM
11/03/11 01:05 PM
Posts: 1,377 Ohio
Todd
Ohio
What kind of cables do you have? The one that I have is a Lokar.
[Re: duspan]
#1106557
11/03/11 04:44 PM
11/03/11 04:44 PM
Posts: 740 Anderson, IN
1969RR
Anderson, IN
what are you using for throttle bracket need pics?
thanks
What type are you needing? I have a couple different stock, OE type if you need. Jeff
[Re: duspan]
#1106562
11/04/11 02:51 AM
11/04/11 02:51 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
i have a lokar cable with the jegs bracket that bolt to the carb studs,the problem is i cannot get full throttle with this set up using the stock gas peddle in car? it makes no difference in what hole i use on the carb?
thanks
I also use the Lokar setup and had the same problem. I had to bend the rod up some at the gas pedal in the car for more pedal travel. Ron
[Re: 383man]
#1106563
11/04/11 07:32 AM
11/04/11 07:32 AM
Posts: 1,377 Ohio
Todd
Ohio
thanks
Had to do the same thing.
