throttle brackets #1106552
11/03/11 12:42 PM
11/03/11 12:42 PM
ma.
duspan Offline OP
duspan  Offline OP
ma.
what are you using for throttle bracket need pics?
thanks
Re: throttle brackets [Re: duspan] #1106553
11/03/11 12:48 PM
11/03/11 12:48 PM
ONTARIO,CANADA
604 Hemi GTX Offline
ONTARIO,CANADA
Not sure what style carb you have, but i use the jegs brand throttle bracket. nice piece
here,s a link
http://www.jegs.com/i/JEGS+Performance+Products/555/15234/10002/-1
Kevin
Re: throttle brackets [Re: duspan] #1106554
11/03/11 01:05 PM
11/03/11 01:05 PM
Ohio
Todd Offline
Todd  Offline
Ohio
What kind of cables do you have? The one that I have is a Lokar.
Re: throttle brackets [Re: duspan] #1106555
11/03/11 01:11 PM
11/03/11 01:11 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
look at hughesperformance.com they have tons of stuff like that
Re: throttle brackets [Re: fishy340] #1106556
11/03/11 02:24 PM
11/03/11 02:24 PM
AndyF Offline
AndyF  Offline
I think you mean www.hughesengines.com or www.manciniracing.com. Both of those places have throttle brackets for Mopar engines.
Re: throttle brackets [Re: duspan] #1106557
11/03/11 04:44 PM
11/03/11 04:44 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
thanks
What type are you needing? I have a couple different stock, OE type if you need. Jeff
Re: throttle brackets [Re: 1969RR] #1106558
11/03/11 05:19 PM
11/03/11 05:19 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i made my own out of a piece of flat aluminium. not hard to do i soda blasted it to give it a uniform finish.
Re: throttle brackets [Re: duspan] #1106559
11/03/11 06:53 PM
11/03/11 06:53 PM
AndyF Offline
AndyF  Offline
Here is the a picture of the tall adjustable bracket that Hughes and Mancini sell. There is also a matching throttle return available with dual springs. These brackets are available for SB, BB and Hemi engines.
Re: throttle brackets [Re: AndyF] #1106560
11/03/11 10:47 PM
11/03/11 10:47 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Built my own heat spacer / shield with throttle bracket and return spring brackets .
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: throttle brackets [Re: chryco] #1106561
11/04/11 01:56 AM
11/04/11 01:56 AM
ma.
duspan Offline OP
duspan  Offline OP
ma.
i have a lokar cable with the jegs bracket that bolt to the carb studs,the problem is i cannot get full throttle with this set up using the stock gas peddle in car? it makes no difference in what hole i use on the carb?
thanks
Re: throttle brackets [Re: duspan] #1106562
11/04/11 02:51 AM
11/04/11 02:51 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
thanks
I also use the Lokar setup and had the same problem. I had to bend the rod up some at the gas pedal in the car for more pedal travel. Ron
Re: throttle brackets [Re: 383man] #1106563
11/04/11 07:32 AM
11/04/11 07:32 AM
Ohio
Todd Offline
Todd  Offline
Ohio
thanks
Had to do the same thing.
