can I mill pistons ? #1106255
11/02/11 09:07 PM
11/02/11 09:07 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
One tought....
Can I mill a set of pistons to get the right dish volume for my combo?
ie.: a set of Diamond piston with a volume of 6.8cc, I could shave 2 mm of the top to have a 10 cc dish
Re: can I mill pistons ? [Re: Wedgeman] #1106256
11/02/11 10:00 PM
11/02/11 10:00 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
Depends on the thickness. I would suggest contacting Diamond Pistons
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: can I mill pistons ? [Re: Wedgeman] #1106257
11/02/11 10:06 PM
11/02/11 10:06 PM
Delray beach, Florida
P
Performance Only Offline
P
One tought....
well, 1 mm = 0.039370 " so you want to mill almost .080" off the top? is this a flat top that want to turn into a dished piston? what is the part # of the piston?
machine shop owner and engine builder
Re: can I mill pistons ? [Re: Performance Only] #1106258
11/02/11 10:55 PM
11/02/11 10:55 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
yes, it is the flat top piston for 408 strokers
Dan
Re: can I mill pistons ? [Re: Wedgeman] #1106259
11/02/11 11:00 PM
11/02/11 11:00 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
NEVER had a custom aftermarket piston made for me-self before ... but I would contact Diamond FIRST. They could have been made SUPER LITE ... then there is no way to cut anything off them safely.
Re: can I mill pistons ? [Re: Wedgeman] #1106260
11/03/11 12:15 AM
11/03/11 12:15 AM
P
P
do you have the part # ?
if it's a shelf piston your going to get pretty thin below the valve pockets. they're probably about .200" thick in that area with that forging. easy enough to measure though.
Re: can I mill pistons ? [Re: Wedgeman] #1106261
11/03/11 01:08 AM
11/03/11 01:08 AM
Norwood NC
HP Engines Offline
HP Engines  Offline
Norwood NC
Hey Wedge, Usually when I run into this situation it deems easier to
use a thicker head gasket,and/or to mill the combustion chambers out in the cyl. heads. to the required cc. Also you only have to set up 2
heads versus setting up 8 individual pistons in the vise. Another thing to keep in mind is when you mill pistons, this will change
the bobweight of the rotating assembly, and thin quench pad.
Cometic will make any thickness of head gasket to your spec if not shelfed.If all else fails, order custom pistons and wait 2 weeks.
However you hash it out, I would try to retain a squish factor of
around .040 - .050 for optimal volumetric effiency.
Hope this info can help. GOOD LUCK!
Re: can I mill pistons ? [Re: HP Engines] #1106262
11/03/11 06:32 PM
11/03/11 06:32 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Thing is ....
I have 55cc chambers indy -1
20.5 step dish pistons KB745
.041 cometic gaskets
255*/263* roller cam
and 10.75 static comp ratio.
I want to raise comp and still use premium pump gas......
Dan
Re: can I mill pistons ? [Re: Wedgeman] #1106263
11/03/11 07:56 PM
11/03/11 07:56 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
Don't do it without a fixture to hold them.
You can't tighten them in a vise without possibly deforming them.
Re: can I mill pistons ? [Re: AAR-B4] #1106264
11/03/11 08:36 PM
11/03/11 08:36 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
...and on this same-vein ... THIS is why most people who build PS moders(so I have been told) ...do ALL machine work BEFORE putting in ring grooves.
Any machine work AFTER the grooves are put in .. it can distort the piston.
Re: can I mill pistons ? [Re: AAR-B4] #1106265
11/03/11 10:02 PM
11/03/11 10:02 PM
Norwood NC
HP Engines Offline
HP Engines  Offline
Norwood NC
I hope anyone capable of machining pistons, knows to clamp them
in a piston vise (or fixture), and not a vise off the railroad.
Wedge if you need to cut .080 off a new piston, to gain compression,
sounds like comp.height of piston is off. I would consider different pistons with a better baseline spec.
