340 TA motor #1105841
11/02/11 11:40 AM
11/02/11 11:40 AM
Carriere, MS
Flucus Offline OP
Flucus  Offline OP
Carriere, MS
i have a 340 TA motor that i am fixing to rebuild for my 70 Dart Swinger and i want to know what your thoughts are about should i rebuild it as a stock motor or should i go a diferent route
64 Barracuda 70 Duster 70 Dart 79 Warlock Truck 92 Dodge 150 05 Magnum
Re: 340 TA motor [Re: Flucus] #1105842
11/02/11 11:47 AM
11/02/11 11:47 AM
New York
EF8aar Offline
EF8aar  Offline
New York
Just a thought... Why not run the numbers by Barry and see if someone is looking for that motor/block?...
Re: 340 TA motor [Re: EF8aar] #1105843
11/02/11 12:07 PM
11/02/11 12:07 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
If its 311170, PM me...
Re: 340 TA motor [Re: Flucus] #1105844
11/02/11 12:08 PM
11/02/11 12:08 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
A 340 makes an awesome 418 stroker & that's what I'd do...
Re: 340 TA motor [Re: Triggerfish] #1105845
11/02/11 12:16 PM
11/02/11 12:16 PM
Carriere, MS
Flucus Offline OP
Flucus  Offline OP
Carriere, MS
i have the car its just a heap that was also was totaled in the 70's. 1 day i plan on rebuilding it
Re: 340 TA motor [Re: Flucus] #1105846
11/02/11 12:20 PM
11/02/11 12:20 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Being that its a small block car, a 340 or 360 stroker is the way to go. There's a few good stroker kits on the market. Light weight, good handling & plenty of torque & hp. I'm sure some members w/ small block strokers will chime in & give you some good build advice.
Re: 340 TA motor [Re: Triggerfish] #1105847
11/02/11 01:29 PM
11/02/11 01:29 PM
dogdays Offline
dogdays  Offline
YOU HAVE THE CAR! Don't mess up the engine. Just a pile of parts with the correct VIN and engine is worth a lot.
I'd suggest finding a 360 block and building a 408 stroker for your Dart. It'll be cheaper in the long run and if something should happen to the block it's just a garden-variety 360. Your 340 TA block is a special block. It's not just another 340 block. It was the only block that came in a real car, that had provisions for four-bolt main caps. It's not the same block you would find in a Swinger 340, for example.
A few months ago I saw a Hemi GTX that a guy found while trying to buy a Hemi. As he looked at the car he realized what a complete car it was, a loaded Hemi 4-speed GTX with numbers-matching engine, etc. He ended up buying the car and totally rebuilt it. Nearly every piece of sheetmetal was replaced in the restoration process. Now this formerly rusty junker has had offers of over $300,000. If it had a replacement engine it'd be worth much less.
So don't mess up that TA block! Or anything else about it.
R.
Re: 340 TA motor [Re: dogdays] #1105848
11/02/11 02:10 PM
11/02/11 02:10 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I missed the part where you had the car too! Maybe you can get one of the new Challenger bodies from Dynacore or whoever that is and build a clone using the original engine. Or sell the engine to another TA or AAR owner that is missing the original engine?
Floyd Lippencott IV
Re: 340 TA motor [Re: mr_340] #1105849
11/02/11 02:42 PM
11/02/11 02:42 PM
Carriere, MS
Flucus Offline OP
Flucus  Offline OP
Carriere, MS
ok thanks for the info i will just store it untill i can tackle the restoration of the car
Re: 340 TA motor [Re: Flucus] #1105850
11/02/11 06:12 PM
11/02/11 06:12 PM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
Send pictures of the car if you can. Definitely wanna see that!
Re: 340 TA motor [Re: Devil] #1105851
11/02/11 10:44 PM
11/02/11 10:44 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I have only heard of one T/A in MS so far & it is restored already. Got any photos?
Re: 340 TA motor [Re: Alaskan_TA] #1105852
11/03/11 09:43 AM
11/03/11 09:43 AM
Carriere, MS
Flucus Offline OP
Flucus  Offline OP
Carriere, MS
i bought the car from a man who worked at the chrysler dealership in new orleans the story he told me was the car was totaled in a test drive and he bought it after that and it set in a pecan orchid until i bought it in 99. the only part of the car that was not rusted down was the fiberglass hood. i dont have any pictures of it and it has been in the back part of my shop since then and its gonna be a big under taken since i have pilled junk and totes of parts all around it and you cant even see the car anymore. i will try to take on the task of cleaning up to get to it to try and get some photos.
