07 caravan brakes sticking #1105824
11/02/11 09:30 AM
11/02/11 09:30 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
I need help. The rear driver side brake caliper sticks intermittently. Changed the caliper and no the pads are not sticking. The caliper is also used. The van has only 50K on it. I am at a lost, someone mentioned to me that water in a brake line would boil and cause the caliper to stick. It just happen this morning not even 2 minute of driving on its 0 degrees Celsius.
Re: 07 caravan brakes sticking [Re: MattW] #1105825
11/02/11 01:36 PM
11/02/11 01:36 PM
Ohio
Todd Offline
Todd  Offline
Ohio
I dont think I would have messed around with a used caliper. Make sure that the pads slide in the braket and the slide pins on the braket if ok go get a NEW caliper. Advance Auto sells them for 40 bucks.
Re: 07 caravan brakes sticking [Re: Todd] #1105826
11/02/11 01:42 PM
11/02/11 01:42 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
ok, grammar police...CALIPER CALIPER....P not B
now that I got that out of my system...yes, I'd go with a new/reman vs. used...
if it's the same side with the used caliPER, I'd look to see if there's a swollen brake hose to it, that can cause calPERS to stick...also make sure the drum-in-hat parking brake isn't hanging up...
2017 Grand Cherokee Overland
Re: 07 caravan brakes sticking [Re: patrick] #1105827
11/02/11 02:57 PM
11/02/11 02:57 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Thanks for the grammar lesson. To think I did that 3 times. It hard to type something on this phone with the auto correction on.
I will look at the hose.
PS its spelling not grammar
Re: 07 caravan brakes sticking [Re: MattW] #1105828
11/02/11 10:16 PM
11/02/11 10:16 PM
PA
70Duster Offline
70Duster  Offline
PA
If you replaced the caliper and it still sticks, even if the hose looks ok, replace it anyway.
