Fuel Pump Location #1105681
11/01/11 11:21 PM
11/01/11 11:21 PM
Illinois
gearhead01 Offline OP
Illinois
I am getting ready to put in the fuel system in the Valiant.
For a strip/street set-up, fuel pump in the trunk or under the trunk floor?
I have cut out the the spare tire well, and filled it in with a sheet metal section. So the the trunk floor is flat.
Any pictures of either set-up will be helpfull.
Thanks, John
1971 Satellite Sebring Plus - 14.46 @ 95.43
1977 Road Runner - N/B 11.02@ 119 Drag Radials
Re: Fuel Pump Location [Re: gearhead01] #1105682
11/02/11 01:04 AM
11/02/11 01:04 AM
Mount it behind and below the fuel outlet on you tank I have my Magnafuel 275 pump mounted in the right rear corner of the inner rear subframe and trunk floor in my Duster. I thought I had picture saved but I don't I used a L bracket to mount off of the base of the pump and used the upright side of the L to mount to the inner subframe rail works good, last a long time I used a stock tank with a three inch deep sump mounted in the center of the tank and then feed it through Aeromotive # 10 AN 80 micron fuel filter and then to the pump with a #10 AN aluminum hard line to the pump inlet I don't like mounting the fuel pump or filter in the trunk, especially in a street car like mine
Re: Fuel Pump Location [Re: Cab_Burge] #1105683
11/02/11 01:49 AM
11/02/11 01:49 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
here's a couple of pix.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Fuel Pump Location [Re: gearhead01] #1105684
11/02/11 05:26 AM
11/02/11 05:26 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
the Duster that I had, I mounted the pump slightly to the rear and alongside of the tank..
in my Camaro(fuel systems are fuel systems)..I mounted the pump below the tank under the trunk floor..
either way the fuel flows good...put a shut off valve at the tank or before the pump...if not, and yu want to change carbs or do something with the system, that fuel will flow like you wont believe...
Re: Fuel Pump Location [Re: gearhead01] #1105685
11/02/11 08:00 AM
11/02/11 08:00 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Best spot I have found...In the fuel tank!
Re: Fuel Pump Location [Re: Dragula] #1105686
11/02/11 11:09 PM
11/02/11 11:09 PM
Illinois
Illinois
Thanks everyone for the information. Gives me a few more ideas.
Smokinwoody; the shut off valve is a great idea. Dragula, whose fuel cell-pump set up is in your pictures. Is it a circle track set-up?
Thanks again
John
