Hemi- Broken push rod end and damaged lifter #1105340
11/01/11 06:33 PM
11/01/11 06:33 PM
Sebring, Florida
Mopar Grandpa Offline OP
Sebring, Florida
Need your opinion here. First time to adjust the valve lash on a hydraulic lifter 2nd gen. Hemi, about 2,000 miles, found one intake way out of adjustment, so I thought. Found the tip of the push rod (lifter end) was broken off. Pulled the lifter out of the hole in 2 pieces, the cup and then the main body. What do you think happened?
I never noticed any loud noise like the lash being way loose. I'm a little puzzled.
Re: Hemi- Broken push rod end and damaged lifter [Re: Mopar Grandpa] #1105341
11/01/11 06:41 PM
11/01/11 06:41 PM
Indiana
maxie Offline
maxie  Offline
Indiana
not a roller? just a normal hydrualic? I may have some hemi pushrods in the garage. A guy here in town has gone threw a bunch of hydrualic rollers in his.
Probably all that "putting" around the show poodle does.
Re: Hemi- Broken push rod end and damaged lifter [Re: maxie] #1105342
11/01/11 06:53 PM
11/01/11 06:53 PM
Sebring, Florida
Sebring, Florida
Yep, just a standard hydraulic Comp Cam. Have it chipped at 6K so I know the engine has not been over reved, which how could it since it only sees car shows......NOT. Overall push rod length is 11.350 which is not a standard Hemi push rod or so I've been told.
Re: Hemi- Broken push rod end and damaged lifter [Re: Mopar Grandpa] #1105343
11/01/11 07:07 PM
11/01/11 07:07 PM
Could mock the pieces back up to see what the clearance actually was but yeah I think you'd have heard it if it was excessive but I try not to assume anything. Prob just a defective part unfortunately
Re: Hemi- Broken push rod end and damaged lifter [Re: RapidRobert] #1105344
11/01/11 08:19 PM
11/01/11 08:19 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I strongly disagree, why would you think it's a defective part?
My $$ is on a incorrectly adjusted valve train.
Sorry about your trouble.
Re: Hemi- Broken push rod end and damaged lifter [Re: Challenger 1] #1105345
11/01/11 10:19 PM
11/01/11 10:19 PM
There's no reason to even disagree as he asked for thoughts/opinions and he will sort thru the thoughts/opinions that are offered
Re: Hemi- Broken push rod end and damaged lifter [Re: RapidRobert] #1105346
11/01/11 10:47 PM
11/01/11 10:47 PM
Cincinnati, Ohio
Cincinnati, Ohio
Because I can and have installed many cams and lifters and have never seen a defective part. After the engine is run they are defective and lot's of people blame quality control which in all the cases I have seen it was installation error.
Re: Hemi- Broken push rod end and damaged lifter [Re: Challenger 1] #1105347
11/01/11 11:05 PM
11/01/11 11:05 PM
NASHVILLE
MAVERICKSHEMI Offline
NASHVILLE
Per my engine builder, He said the problem with the push rods was the motor sat to long..
Ofcourse 4 other engine builders said lack of oil was the problem..
Thanks engine builder!!
Re: Hemi- Broken push rod end and damaged lifter [Re: MAVERICKSHEMI] #1105348
11/02/11 12:18 AM
11/02/11 12:18 AM
Sebring, Florida
Sebring, Florida
Okay guys, let's not beat each other up on this question. Here is a little background. The engine was built by ICH (No bashing is allowed) and was run and dynoed in November of 2007. I brought it home and installed it in my Barracuda in July of 2008 when it was fired for the first time since November of 2007. It fired right away, had immediate oil pressure and ran very, very well. Absolutely no problems.
The push rod does not indicate any oiling problems as there is no indication of getting hot at the point of fracture, ie; no blue/black marks. Just appears as a shear of the push rod end. The lifter is my biggest question. Did the failure of the push rod cause the destruction of the lifter or was it the other way around? I have built quite a few racing engines in my day but have never seen this.
And this situation only happened with one intake valve. I just don't think it was an oiling issue based on the evidence. I would still like to learn from those that have experienced the same issue.
Re: Hemi- Broken push rod end and damaged lifter [Re: Mopar Grandpa] #1105349
11/02/11 12:25 AM
11/02/11 12:25 AM
adjustable rocker arms I'm assuming. up top on that arm/p rod did everything look OK/adjustment look the same as the rest?
Re: Hemi- Broken push rod end and damaged lifter [Re: RapidRobert] #1105350
11/02/11 12:50 AM
11/02/11 12:50 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I had the same problem way back in the 80s, with factory pushrods. Cups were cracking and breaking off.
Changed over to Crower pushrods and never had a problem since. If the pushrod became too short due to the cup breaking the lifter can come apart since it is not under pressure.
Re: Hemi- Broken push rod end and damaged lifter [Re: Challenger 1] #1105351
11/02/11 10:17 AM
11/02/11 10:17 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Then you live in a perfect world , I seen a snap ring half pop out of a hyd. lifter and eat a cam , how is that installation error ?
Re: Hemi- Broken push rod end and damaged lifter [Re: Mopar Grandpa] #1105352
11/02/11 10:20 AM
11/02/11 10:20 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I would be checking guide clearance and make sure the valve wasn't the culprit. What is the pressure on the spring open and closed? I can remember seeing this posted that the same thing happened to a hollow body solid lifter.
