Re: Hemi- Broken push rod end and damaged lifter
[Re: RapidRobert]
#1105344
11/01/11 08:19 PM
11/01/11 08:19 PM
Challenger 1
Cincinnati, Ohio
Prob just a defective part unfortunately
I strongly disagree, why would you think it's a defective part?
My $$ is on a incorrectly adjusted valve train. Sorry about your trouble.
[Re: RapidRobert]
#1105346
11/01/11 10:47 PM
11/01/11 10:47 PM
Challenger 1
Cincinnati, Ohio
There's no reason to even disagree as he asked for thoughts/opinions and he will sort thru the thoughts/opinions that are offered
Because I can and have installed many cams and lifters and have never seen a defective part. After the engine is run they are defective and lot's of people blame quality control which in all the cases I have seen it was installation error.
[Re: Challenger 1]
#1105347
11/01/11 11:05 PM
11/01/11 11:05 PM
Posts: 370 NASHVILLE
MAVERICKSHEMI
NASHVILLE
Per my engine builder, He said the problem with the push rods was the motor sat to long..
Ofcourse 4 other engine builders said lack of oil was the problem..
Thanks engine builder!!
[Re: Mopar Grandpa]
#1105349
11/02/11 12:25 AM
11/02/11 12:25 AM
RapidRobert
adjustable rocker arms I'm assuming. up top on that arm/p rod did everything look OK/adjustment look the same as the rest?
[Re: Challenger 1]
#1105351
11/02/11 10:17 AM
11/02/11 10:17 AM
Posts: 75,092 A Banana Republic near you.
JohnRR
Then you live in a perfect world , I seen a snap ring half pop out of a hyd. lifter and eat a cam , how is that installation error ?
[Re: Mopar Grandpa]
#1105352
11/02/11 10:20 AM
11/02/11 10:20 AM
JohnRR
Okay guys, let's not beat each other up on this question. Here is a little background. The engine was built by ICH (No bashing is allowed) and was run and dynoed in November of 2007. I brought it home and installed it in my Barracuda in July of 2008 when it was fired for the first time since November of 2007. It fired right away, had immediate oil pressure and ran very, very well. Absolutely no problems.
The push rod does not indicate any oiling problems as there is no indication of getting hot at the point of fracture, ie; no blue/black marks. Just appears as a shear of the push rod end. The lifter is my biggest question. Did the failure of the push rod cause the destruction of the lifter or was it the other way around? I have built quite a few racing engines in my day but have never seen this.
And this situation only happened with one intake valve. I just don't think it was an oiling issue based on the evidence. I would still like to learn from those that have experienced the same issue.
I would be checking guide clearance and make sure the valve wasn't the culprit. What is the pressure on the spring open and closed? I can remember seeing this posted that the same thing happened to a hollow body solid lifter.
