318 to 360 motor mounts/brackets #1104976
11/01/11 12:18 AM
11/01/11 12:18 AM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I want to put a 5.9 magnum in my 318 A body. I don't have any motor brackets/mounts. Are all small block the same or??? I do have a set of 318 B body brackets/mounts, are they the same?
Re: 318 to 360 motor mounts/brackets [Re: VITC_GTX] #1104977
11/01/11 12:56 AM
11/01/11 12:56 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
The 360 has a different mount bracket on one side, don't remember which side though. I'm thinking DS.
I got a set of 360 brackets from a B body & they didn't line up in my Dart, so i ended up useing my original 318 brackets & did some fabbing on the one bracket, These were the Bisket mounts.
This is what the "360" brackets look like, I was "told" these were for a B body , But they did bolt up to the engine.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: 318 to 360 motor mounts/brackets [Re: joedust451] #1104978
11/01/11 11:28 AM
11/01/11 11:28 AM
Andrewh Offline
Andrewh  Offline
the 360 has wider mounts on one side.
you can use spacers on the that side to make it fit with the 318 mount.
Re: 318 to 360 motor mounts/brackets [Re: Andrewh] #1104979
11/01/11 11:32 AM
11/01/11 11:32 AM
Franklin Co. Illinois
runinonmt Offline
runinonmt  Offline
A 7/16" nut makes an excellent spacer. I ground the flats off of mine for looks,but it's not necessary.
Ron
In sixty-five I was seventeen and running up one-o-one I don't know where I'm running now, I'm just running on Jackson Browne-Running On Empty
Re: 318 to 360 motor mounts/brackets [Re: Andrewh] #1104980
11/01/11 01:21 PM
11/01/11 01:21 PM
Central TX
roe Offline
roe  Offline
Central TX
Thats what I did for mine too. Just used grade 8 washers. So you should be fine to pick up some parts store 318 mounts, and just use grade 8 washers to take up the slack.
roe
edit: pass mount was the same, I only used washers on the drivers mount
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: 318 to 360 motor mounts/brackets [Re: roe] #1104981
11/01/11 03:10 PM
11/01/11 03:10 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
The brackets that JoeDust posted are indeed for 340/360 B/E engine. The pass side is the same 318, only drivers side is different. The bracket on the left side of his pic is drivers side mount.
It's the orientation where the biscuit bolts to the bracket. Here's a pic of a drivers side 318 bracket and one modded for use on a 340/360.
Re: 318 to 360 motor mounts/brackets [Re: RobX4406] #1104982
11/04/11 01:14 AM
11/04/11 01:14 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Are the B body 318 brackets the same as the A body brackets? I have a set of B body 318 brackets I will use if I can space them as stated above.
Re: 318 to 360 motor mounts/brackets [Re: VITC_GTX] #1104983
11/04/11 02:54 PM
11/04/11 02:54 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
no a-body and b/e body mounts do not interchange, simple as that, look in the A-body or small block parts for sale section, Wayne Brewer has a set of 340-360 67-72 A-body steel engine mounting brackets for sale.
Re: 318 to 360 motor mounts/brackets [Re: Joesixpack] #1104984
11/04/11 02:56 PM
11/04/11 02:56 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
A-body 340-360 mounts are pictured here.
Re: 318 to 360 motor mounts/brackets [Re: Joesixpack] #1104985
11/04/11 02:59 PM
11/04/11 02:59 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
B/E 340-360 mounts are pictured here
Re: 318 to 360 motor mounts/brackets [Re: Joesixpack] #1104986
11/10/11 01:16 AM
11/10/11 01:16 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Thanks. I ended up going this route.
