Re: 318 to 360 motor mounts/brackets
[Re: VITC_GTX]
#1104977
11/01/11 12:56 AM
11/01/11 12:56 AM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
I want to put a 5.9 magnum in my 318 A body. I don't have any motor brackets/mounts. Are all small block the same or??? I do have a set of 318 B body brackets/mounts, are they the same?
The 360 has a different mount bracket on one side, don't remember which side though. I'm thinking DS.
I got a set of 360 brackets from a B body & they didn't line up in my Dart, so i ended up useing my original 318 brackets & did some fabbing on the one bracket, These were the Bisket mounts. This is what the "360" brackets look like, I was "told" these were for a B body , But they did bolt up to the engine.
[Re: Andrewh]
#1104979
11/01/11 11:32 AM
11/01/11 11:32 AM
Posts: 416 Franklin Co. Illinois
runinonmt
A 7/16" nut makes an excellent spacer. I ground the flats off of mine for looks,but it's not necessary. Ron
In sixty-five I was seventeen and running up one-o-one
I don't know where I'm running now, I'm just running on
Jackson Browne-Running On Empty
[Re: Andrewh]
#1104980
11/01/11 01:21 PM
11/01/11 01:21 PM
Posts: 3,344 Central TX
roe
Central TX
Thats what I did for mine too. Just used grade 8 washers. So you should be fine to pick up some parts store 318 mounts, and just use grade 8 washers to take up the slack. roe
edit: pass mount was the same, I only used washers on the drivers mount
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
[Re: RobX4406]
#1104982
11/04/11 01:14 AM
11/04/11 01:14 AM
Posts: 4,929 Tri-Cities, Washington
VITC_GTX
The brackets that JoeDust posted are indeed for 340/360 B/E engine. The pass side is the same 318, only drivers side is different. The bracket on the left side of his pic is drivers side mount.
It's the orientation where the biscuit bolts to the bracket. Here's a pic of a drivers side 318 bracket and one modded for use on a 340/360.
Are the B body 318 brackets the same as the A body brackets? I have a set of B body 318 brackets I will use if I can space them as stated above.
[Re: Joesixpack]
#1104986
11/10/11 01:16 AM
11/10/11 01:16 AM
VITC_GTX
no a-body and b/e body mounts do not interchange, simple as that, look in the A-body or small block parts for sale section, Wayne Brewer has a set of 340-360 67-72 A-body steel engine mounting brackets for sale.
Thanks. I ended up going this route.
