How do you select the right cam? #1104512
10/31/11 02:10 AM
10/31/11 02:10 AM
California
moparbroz Offline OP
California
I have a 440 E stamp non HP. The guy I bought it from had it in a truck that he was going to tow a trailer with. It is rebuilt and never ran. I am eventually going to run HP exhaust manifolds so that part is known. I have not yet selected a carburetor and can go any direction I need to on that. I want a streetable HP cam for my 1972 Plymouth SSP. Suggestions? Thanks in advance.
Hebrews 11:1
Re: How do you select the right cam? [Re: moparbroz] #1104513
10/31/11 02:50 AM
10/31/11 02:50 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Stock heads? What pistons are in it?
Re: How do you select the right cam? [Re: DaytonaTurbo] #1104514
10/31/11 02:57 AM
10/31/11 02:57 AM
California
California
Stock heads and I don't know what pistons are installed. It is a non HP build I am fairly certain. It's not a magnum.
Hebrews 11:1
Re: How do you select the right cam? [Re: moparbroz] #1104515
10/31/11 03:48 AM
10/31/11 03:48 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
So if we assume there factory pistons then there around .080" or there abouts in the hole, thats if it wasn't bored & just a re-ring, You really need to find out before picking a cam, If there factory the compressions around 8.6-8.7.1 for the 69 non HP 440. Without guessing you may need to pop a head off & check, because if they installed the run of the mill badger pistons in the cheapo rebuild kit they sit low in the deck & the compression won't be over 8.1
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: How do you select the right cam? [Re: joedust451] #1104516
10/31/11 04:35 AM
10/31/11 04:35 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Not really enough info to go on. But...
I'm getting an overall vibe of somewhere between a Mopar Performance 440/383 repro High Performance cam and a Comp XE268. Carb would be a Edlebrock 750.
Re: How do you select the right cam? [Re: autoxcuda] #1104517
10/31/11 06:04 AM
10/31/11 06:04 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
call one of the cam builders.. give them all the info and they will advise the best cam for you...
I am truckless..
Re: How do you select the right cam? [Re: 340SHORTY] #1104518
10/31/11 06:26 AM
10/31/11 06:26 AM
Manitoba, Canada
Manitoba, Canada
Until you pull a head and tell us how far down in the hole your pistons are, we can't tell you jack squat for what would be a good cam. Tell us how far the pistons are down in the hole, and if they're flat tops, dome, dish or have valve reliefs. Otherwise we'll just have to assume he put in smogger 70's 440 pistons in which case you'll want a really mild cam to maintain driveability.
Re: How do you select the right cam? [Re: DaytonaTurbo] #1104519
10/31/11 09:13 AM
10/31/11 09:13 AM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
Do yourself a favor,, ask the experts...Find a cam manufacturer , give them all the details and let them build you a cam..I use Tim at bullet cams for all my big block jobs...never been wrong yet..
Re: How do you select the right cam? [Re: DaytonaTurbo] #1104520
10/31/11 10:23 AM
10/31/11 10:23 AM
California
California
Sounds good. I will pull a head and get back to you guys. Thanks.
Hebrews 11:1
Re: How do you select the right cam? [Re: moparbroz] #1104521
10/31/11 03:35 PM
10/31/11 03:35 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Very smart move, otherwise A GOOD cam guy will want to know what the compression ratio is, if they don't, I wouldn't trust them, Tim at Bullet cams knows his stuff & he knows Mopar.
Re: How do you select the right cam? [Re: joedust451] #1104522
10/31/11 03:44 PM
10/31/11 03:44 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
how do I pick a cam?
I call a cam maker and ask them to pick it for me!
but, they WILL want to know all the info that was already asked...compression ratio or at least the info to calculate it, like flat top, dished, valve reliefs, domed etc. on the pistons, how far in the hole, how thick the head gasket, open/closed chamber heads, etc.
plus vehicle weight, rear gear ratio, auto vs stick, power brakes vs standard, etc.
all that information is needed so they know if you need good idle vacuum for the brake booster, or if you can get away with less idle vacuum on standard brakes, where the stall will flash too, etc, so they don't give you a power band that's all used up by the time your converter finally "grabs", etc.
**Photobucket sucks**
Re: How do you select the right cam? [Re: 70Cuda383] #1104523
10/31/11 08:45 PM
10/31/11 08:45 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
general rule of thumb
.390 to .450 lift = stock
.450 to .500 lift = sweet
.500 to .570 lift = hold on
over .570 = check your shorts
Re: How do you select the right cam? [Re: joelson6] #1104524
10/31/11 08:57 PM
10/31/11 08:57 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Think about where you WANT the powerband. A Car with a loose converter and a driver who likes to spin a motor to 6500 can benefit from a big cam.
A tight converter and never spinning above 5000 is a TOTALLY different story.
And with power brakes I would not venture beyond 240 duration at .050. (or above 280 at .000)
I run the 60303 Lunati with power brakes and its fine with about 11 inches of vacuum (IIRC) at 750 idle.
Re: How do you select the right cam? [Re: moparbroz] #1104525
10/31/11 09:28 PM
10/31/11 09:28 PM
ill
dennismopar73 Offline
ill
the 268 -272 cams would be good choice, dont thing i would go any bigger as the power brakes would suffer
Re: How do you select the right cam? [Re: joelson6] #1104526
10/31/11 10:53 PM
10/31/11 10:53 PM
Manitoba, Canada
Manitoba, Canada
Huh? Comp, lunati and hughes make some hydraulic cams near .500 lift that aren't much more aggressive than a stock cam. And typically the duration that comes with a .500 lift cam vs a .570 lift cam is a huge difference. Using valve lift to describe camshaft characteristics was MP's old way of educating the ignorant back in the day.
Re: How do you select the right cam? [Re: DaytonaTurbo] #1104527
10/31/11 11:21 PM
10/31/11 11:21 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
what part of general rule of thumb didn't you get? i figures i get a response like that.
Re: How do you select the right cam? [Re: joelson6] #1104528
11/01/11 12:19 AM
11/01/11 12:19 AM
Manitoba, Canada
Manitoba, Canada
A general rule of thumb is something that makes some basic level of sense. Like rightey tighey, left loosey. Or 10psi oil pressure per 1000rpm. Or going with a 3" dual exhaust for anything over 475hp. Lumping a .500 lift cam together with a .570 cam does not make any sense. At all. And only serves to further confuse those who do not have a good understanding of camshaft timing fundamentals. There's way too much variation in cam design for blanket statements like yours to have any use.
Re: How do you select the right cam? [Re: DaytonaTurbo] #1104529
11/01/11 12:45 AM
11/01/11 12:45 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
I agree wth you Datona, I laughed after reading his 1st. responce , Made no lick of sense to me neither . I'm sure i'll get a tongue lashing for my responce
Re: How do you select the right cam? [Re: joelson6] #1104530
11/01/11 09:18 AM
11/01/11 09:18 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
lift doesn't really mean squat...it's duration that will determine the drivability....a MP .484" lift cam is a pretty wild cam, because it's ~240@.050 duration, with lots of overlap, while say the hydraulic roller in my 318 is pretty mild, with 208@050 duration, but it has .506" lift...
for a low comp, street oriented 440, I think most tend to overcam. I'd look at a lunati voodoo 60302 or 60303, using comp #911 springs on the heads. I'd probably steer towards the 60302, especially if you're looking at a stock converter, stock exhaust manifolds, and gearing in the 3.23 or so or taller.
2017 Grand Cherokee Overland
Re: How do you select the right cam? [Re: patrick] #1104531
11/01/11 09:36 AM
11/01/11 09:36 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Well its not explained in one post.
If you were to make a list of all the factors, then have to explain each one on that list and then break it down further there are probably books on it and just like most books, without the hands on time its still just a book.
Its much easier to spec a cam for your car you know well vs others or just filling out a general check list.
