Who else has a powermaster mini starter? #1104223
10/30/11 05:10 PM
10/30/11 05:10 PM
illinois
bigblk66_coronet Offline OP
illinois
Ok guys ive had a powermaster mini started on my car for 7 years.When i put the motor in it was an absolute nightmare getting the wires hooked up because they are on top and to the inside. Well i got the motoe out and had the same stupid problem trying to get the wires off! Im running TTI headers also. Anyone else have the same problem trying to get the wires hooked up? I cant figure out ANY good way to do! Anyone figure out an easier way to do it?.............lol
Re: Who else has a powermaster mini starter? [Re: bigblk66_coronet] #1104224
10/30/11 05:26 PM
10/30/11 05:26 PM
Chicago illinois
ChinooK440 Offline
ChinooK440  Offline
Chicago illinois
attach the wires to starter before you bolt it in and if your removing it unbolt the starter first then disconnect the wires.
Re: Who else has a powermaster mini starter? [Re: ChinooK440] #1104225
10/30/11 05:48 PM
10/30/11 05:48 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
That's how I install/uninstall my mini starter.
Scott
1969 Super Bee, 383/4 speed
Re: Who else has a powermaster mini starter? [Re: StukaJU87] #1104226
10/30/11 07:03 PM
10/30/11 07:03 PM
Posting from 1893 in NW FL
TheBlueBeast Offline
X3
Re: Who else has a powermaster mini starter? [Re: ChinooK440] #1104227
10/30/11 09:07 PM
10/30/11 09:07 PM
illinois
illinois
Thats all fine and great but them stupid headers are in the way all the time!........lol
Re: Who else has a powermaster mini starter? [Re: bigblk66_coronet] #1104228
10/30/11 09:45 PM
10/30/11 09:45 PM
You don't own a sawzall?!
Re: Who else has a powermaster mini starter? [Re: bigblk66_coronet] #1104229
10/30/11 10:43 PM
10/30/11 10:43 PM
Carson City, Nevada
RobbMc Offline
RobbMc  Offline
Carson City, Nevada
Designing a better mouse trap always seems to lead to the evolution of smarter mice. www.robbmcperformance.com
Re: Who else has a powermaster mini starter? [Re: RobbMc] #1104230
10/31/11 12:29 AM
10/31/11 12:29 AM
This starter allows you to rotate the solenoid to any position:
http://www.robbmcperformance.com/products/mopar_starter.html
http://www.robbmcperformance.com/products/starter_home.html#comparison
Ya and real pricey at $329.
Re: Who else has a powermaster mini starter? [Re: bigblk66_coronet] #1104231
10/31/11 12:33 AM
10/31/11 12:33 AM
ill
dennismopar73 Offline
ill
we don't have that issue , we don't run tti headers , we have slip tubed super comps 2" take the back tube off there's the wires , like majic!
67 coronet
Re: Who else has a powermaster mini starter? [Re: dennismopar73] #1104232
10/31/11 11:52 AM
10/31/11 11:52 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use a Power Master starter with TTI headers. But I removed the plastic adapter from the starter main battery cable stud. Mine fits with no problems and I can get the wires of with the starter hooked up. Ron
Re: Who else has a powermaster mini starter? [Re: 383man] #1104233
10/31/11 02:14 PM
10/31/11 02:14 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
Just put in a PowerMaster clock-able starter in mine using TTI headers. I wired up a quick-connect and made the primary wires longer. Hook up the wires to the starter, then they run towards the back of the motor. I can reach through the header pipes and reach the solenoid, but it is a royal PITA! Now, I just wire the starter, running the wires back toward the rear of the engine and then connect the quick-connect. Super easy now. I got the connectors at O'Reilly Auto Parts. Jeff
