AFR does affect idle RPM, suprised! #1103880
10/29/11 10:35 PM
10/29/11 10:35 PM
Cab_Burge Offline OP
I learned something new today, the AFR can and did affect the idle RPM by changing the AFR from 13.8 to 14.5 and then leaned out to 16.8 to 17.5 AFR. I had the motor idling around 1200 RPM when it was at 16.8 AFR so I enrichened the idle mixture screws one full turn which brought the AFR down to 13.5 to 14.3 or so, it also dropped the idle RPM 150 to 200 RPM down to 950 to 1000 RPM I was testing and setting up a new to me HP 9375-2 Dominator so I could drive the car, this carb. fought me all the way, leaking, flooding and not working properly at all I whupped it though Now if it will run as good as the old one I will be a happy camper, and carb tester
Re: AFR does affect idle RPM, suprised! [Re: Cab_Burge] #1103881
10/31/11 11:27 PM
10/31/11 11:27 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
Uh, you just learned that??? Yeah, and the World is round too......I just gotta bust your balls....
If you can't handle the truth, you're living a lie.......
Re: AFR does affect idle RPM, suprised! [Re: Big Squeeze] #1103882
10/31/11 11:38 PM
10/31/11 11:38 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Don't put a vacuum gauge on it, you might see it affect that as well...Just a hint, if its a pump gas motor, the E10 in the fuel now affects the target AFR....
Re: AFR does affect idle RPM, suprised! [Re: Dragula] #1103883
11/01/11 03:32 AM
11/01/11 03:32 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Vacuum?? AFR?? You guys are making my head hurt.
Let go at the first flash of yellow,
add fuel between rounds...that's enough to remember right there!!!
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: AFR does affect idle RPM, suprised! [Re: MoparBilly] #1103884
11/01/11 03:38 AM
11/01/11 03:38 AM
Arizona
Chris'sBarracuda Offline
Arizona
Chris..
Re: AFR does affect idle RPM, suprised! [Re: Chris'sBarracuda] #1103885
11/01/11 10:40 AM
11/01/11 10:40 AM
Dragula Offline
Dragula  Offline
With more information, generally brings one, more knowledge...Generally speaking.
But the new ethanol based pump fuel is changing what we know for target AFR's so be careful with all the new info your aquiring. The fuel you run changes things as well.
Re: AFR does affect idle RPM, suprised! [Re: Dragula] #1103886
11/01/11 11:35 AM
11/01/11 11:35 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Dragula,
Was talking with an extremely successfull racer last weekend who has a reputation for his meticulous approach.
He mentioned converting one of his cars to E85. We questioned whether the stuff at the pump was consistant. He told us he bought 2 separate meters, buys E98 and mixes his own to get consistant E85! He stated the pump stuff generally tests out at 86-88. So I have little doubt that you are correct about dealing with the E10.
Re: AFR does affect idle RPM, suprised! [Re: MoparBilly] #1103887
11/01/11 05:24 PM
11/01/11 05:24 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Re: AFR does affect idle RPM, suprised! [Re: Big Squeeze] #1103888
11/01/11 08:16 PM
11/01/11 08:16 PM
organ
maximum entropy Offline
organ
you said what i was thinking. thanks.
Re: AFR does affect idle RPM, suprised! [Re: maximum entropy] #1103889
11/01/11 09:18 PM
11/01/11 09:18 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Cab, you didn't know that . Do you have that much time on yours hands
Anytime you change the IFR in the idle it will affect the RPM
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: AFR does affect idle RPM, suprised! [Re: joedust451] #1103890
11/01/11 09:50 PM
11/01/11 09:50 PM
I didn't change the idle fuel restrictors, I changed the air fuel ratio by adjusting the idle mixture screws. I have been able to slow a motor idle RPM down by adjusting the idle mixture in (leaner) and I have been able to make them richer with the idle mixture screws This is the first motor and carb. that I can remember speeding up the RPM by making it leaner from 13,8 or so to 16.3+ AFR I have seen the idle vacume go up with RPM going up, but not change if the RPM didn't change
Re: AFR does affect idle RPM, suprised! [Re: Cab_Burge] #1103891
11/01/11 11:16 PM
11/01/11 11:16 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
does it idle better fatter or did it idle better leaner?
Re: AFR does affect idle RPM, suprised! [Re: sixpackgut] #1103892
11/02/11 01:08 AM
11/02/11 01:08 AM
It sped up when I leaned it down, I liked it better It started to stink at 14.2 to 14.8 AFR The other carbs and motors I have had in the car with this dual wideban (Innovate) idled fine at 14.3 to 15.3 and din't stink
Re: AFR does affect idle RPM, suprised! [Re: Cab_Burge] #1103893
11/02/11 01:16 AM
11/02/11 01:16 AM
Tomorrow.
Damned67 Offline
Damned67  Offline
Tomorrow.
When was the last time you calibrated the meter?
I think mines due, as my plugs indicate a richer mix than the meter is showing.
Re: AFR does affect idle RPM, suprised! [Re: Cab_Burge] #1103894
11/02/11 01:22 AM
11/02/11 01:22 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Cab, normally, well in all cases, IF your idle is on the righer end, leaning it out will raise the idle, once you get to that sweet spot where you get the highest vacuum, you will get the highest idle, going too lean will effect the idle also, so if the idle came up as you "leaned" it out it was too rich to begin with. IMO the best AFR for idle/cruise is in the mid-upper 13s, best WOT is 12.6-12.8, 14s is better for fuel economy, but might feel abit lazy over mid-upper 13s in a perf. engine.
Re: AFR does affect idle RPM, suprised! [Re: Damned67] #1103895
11/02/11 01:23 AM
11/02/11 01:23 AM
I just calibrated both sides two months ago before going to the bracket finals, probally around twenty runs and 8 to 10 street miles, all on unleaded non ethanol 93 octane Oregon pump gas Four different carbs and a bunch of jet channging also in that time I can't leave a good thing alone
Re: AFR does affect idle RPM, suprised! [Re: Cab_Burge] #1103896
11/02/11 01:25 AM
11/02/11 01:25 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Sorry Cab, I ment AFR my badd
Re: AFR does affect idle RPM, suprised! [Re: Cab_Burge] #1103897
11/02/11 10:30 AM
11/02/11 10:30 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
FWIW, my idle afr is almost 17-1. i dont know why nor do i care, thats where it works best. when cruising and everything else its spot on but idling its just doesnt seem to either read right or thats what it likes and i dont and cant find any exhaust leaks or anything like that
Re: AFR does affect idle RPM, suprised! [Re: Cab_Burge] #1103898
11/02/11 11:47 AM
11/02/11 11:47 AM
New Jersey
Craig Offline
Craig  Offline
New Jersey
CAB, if this is an automatic trans, was your idle mix testing in park or in gear? I have found that the idle mix that gives the highest idle rpm in park is often not the same setting for in gear. I prefer a solid idle in gear to prevent loading up or stalling at a light.
67 Dart, 426 Hemi, 9.23/145mph, 3400lbs, footbraked, owned since 1982
Re: AFR does affect idle RPM, suprised! [Re: Cab_Burge] #1103899
11/02/11 12:13 PM
11/02/11 12:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont use the A/F meter to set the idle... I get it
to where it idles the best in N and in gear... then
if I feel like I want to know what the A/F ratio is then
I put the meter on it
