AFR does affect idle RPM, suprised!
#1103880
10/29/11 10:35 PM
10/29/11 10:35 PM
Posts: 43,259 Bend,OR USA
Cab_Burge
I learned something new today, the AFR can and did affect the idle RPM by changing the AFR from 13.8 to 14.5 and then leaned out to 16.8 to 17.5 AFR. I had the motor idling around 1200 RPM when it was at 16.8 AFR so I enrichened the idle mixture screws one full turn which brought the AFR down to 13.5 to 14.3 or so, it also dropped the idle RPM 150 to 200 RPM down to 950 to 1000 RPM I was testing and setting up a new to me HP 9375-2 Dominator so I could drive the car, this carb. fought me all the way, leaking, flooding and not working properly at all I whupped it though Now if it will run as good as the old one I will be a happy camper, and carb tester
Re: AFR does affect idle RPM, suprised!
[Re: Dragula]
#1103883
11/01/11 03:32 AM
11/01/11 03:32 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Vacuum?? AFR?? You guys are making my head hurt. Let go at the first flash of yellow, add fuel between rounds...that's enough to remember right there!!!
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: MoparBilly]
#1103884
11/01/11 03:38 AM
11/01/11 03:38 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Chris..
[Re: Dragula]
#1103886
11/01/11 11:35 AM
11/01/11 11:35 AM
MoparBilly
Phoenix, AZ
Dragula, Was talking with an extremely successfull racer last weekend who has a reputation for his meticulous approach. He mentioned converting one of his cars to E85. We questioned whether the stuff at the pump was consistant. He told us he bought 2 separate meters, buys E98 and mixes his own to get consistant E85! He stated the pump stuff generally tests out at 86-88. So I have little doubt that you are correct about dealing with the E10.
[Re: joedust451]
#1103890
11/01/11 09:50 PM
11/01/11 09:50 PM
Cab_Burge
Cab, you didn't know that . Do you have that much time on yours hands
Anytime you change the IFR in the idle it will affect the RPM
I didn't change the idle fuel restrictors, I changed the air fuel ratio by adjusting the idle mixture screws. I have been able to slow a motor idle RPM down by adjusting the idle mixture in (leaner) and I have been able to make them richer with the idle mixture screws This is the first motor and carb. that I can remember speeding up the RPM by making it leaner from 13,8 or so to 16.3+ AFR I have seen the idle vacume go up with RPM going up, but not change if the RPM didn't change
[Re: Cab_Burge]
#1103891
11/01/11 11:16 PM
11/01/11 11:16 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
does it idle better fatter or did it idle better leaner?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Cab_Burge]
#1103893
11/02/11 01:16 AM
11/02/11 01:16 AM
Posts: 2,309 Tomorrow.
Damned67
Tomorrow.
It sped up when I leaned it down, I liked it better It started to stink at 14.2 to 14.8 AFR The other carbs and motors I have had in the car with this dual wideban (Innovate) idled fine at 14.3 to 15.3 and din't stink
When was the last time you calibrated the meter? I think mines due, as my plugs indicate a richer mix than the meter is showing.
[Re: Cab_Burge]
#1103894
11/02/11 01:22 AM
11/02/11 01:22 AM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
Cab, normally, well in all cases, IF your idle is on the righer end, leaning it out will raise the idle, once you get to that sweet spot where you get the highest vacuum, you will get the highest idle, going too lean will effect the idle also, so if the idle came up as you "leaned" it out it was too rich to begin with. IMO the best AFR for idle/cruise is in the mid-upper 13s, best WOT is 12.6-12.8, 14s is better for fuel economy, but might feel abit lazy over mid-upper 13s in a perf. engine.
[Re: Damned67]
#1103895
11/02/11 01:23 AM
11/02/11 01:23 AM
Cab_Burge
I just calibrated both sides two months ago before going to the bracket finals, probally around twenty runs and 8 to 10 street miles, all on unleaded non ethanol 93 octane Oregon pump gas Four different carbs and a bunch of jet channging also in that time I can't leave a good thing alone
[Re: Cab_Burge]
#1103896
11/02/11 01:25 AM
11/02/11 01:25 AM
joedust451
super gas
super gas
Branson, Mo.
Sorry Cab, I ment AFR my badd
[Re: Cab_Burge]
#1103897
11/02/11 10:30 AM
11/02/11 10:30 AM
sixpackgut
Charleston
FWIW, my idle afr is almost 17-1. i dont know why nor do i care, thats where it works best. when cruising and everything else its spot on but idling its just doesnt seem to either read right or thats what it likes and i dont and cant find any exhaust leaks or anything like that
[Re: Cab_Burge]
#1103898
11/02/11 11:47 AM
11/02/11 11:47 AM
Posts: 642 New Jersey
Craig
New Jersey
CAB, if this is an automatic trans, was your idle mix testing in park or in gear? I have found that the idle mix that gives the highest idle rpm in park is often not the same setting for in gear. I prefer a solid idle in gear to prevent loading up or stalling at a light.
67 Dart, 426 Hemi, 9.23/145mph, 3400lbs, footbraked, owned since 1982
[Re: Cab_Burge]
#1103899
11/02/11 12:13 PM
11/02/11 12:13 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I dont use the A/F meter to set the idle... I get it to where it idles the best in N and in gear... then if I feel like I want to know what the A/F ratio is then I put the meter on it
