Hey all,
I would like your opinion on where to install my cam.
69 B body, 451 (400 rods, KB 215's), mild ported 213's w/ 2.14/1.81, 10.2-1 CR, 3x2 bbl, Hedman Elite 1 3/4-3 hedders, 727, 3200-3600 stall, Dana 60 4.10's, 28" tires, power brakes.
I have an Engle K56/58 (same as Hughes 2330)
223/230 @ .050, 504/514 lift, 110 Lsa.
Straight up? Advanced?
Need vacuum for brakes, Dont want to ping, but I also realize this is kind of a small cam for my combo.
Plus, Im not sure if the grind is already advanced (kind of like comp who grinds LSA at 110 and ICA at 106 for example)
BTW, Im also not "married" to this cam, so some other suggestions are okay if you want. I do prefer a torquier cam though...
Also, I lost my degree wheel when I moved (along with a bunch of other s**t). I have one of those 3 way timing gears. Is that all I need or should I get another dgree wheel?
Thanks for any and all advice!
