Re: What hood scoop for my car?
[Re: fishy340]
#1103179
10/28/11 08:36 PM
10/28/11 08:36 PM
Posts: 1,675 Mi.
G-Money1320
Mi.
Hey Brian, why not just go to a bigger style like the Hemi Darts had? It would give you more clearance and im assuming more air,still look factory and you could seal it to the carb. It sucks you have to make a change and try to match the paint.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out. 11.06 open headers----so far!!
[Re: fishy340]
#1103180
10/28/11 11:17 PM
10/28/11 11:17 PM
Posts: 3,456 Out West
408strokerdart
Out West
um did u say 640ci,does that mean what u have is gonna be for sale?..let me know im ready to pull the trigger on buying a new sb,very very soon.
Not going up for sale soon. Going to take a long time to get the KB block and get the rest of the parts rounded up.
[Re: 408strokerdart]
#1103182
10/29/11 10:41 AM
10/29/11 10:41 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Thats a bummer as I think your car looks great with the 6pk scoop. Ron
Thanks Ron, I'm not overly excited about it either, but in the name of progress it has to be done. Six pak isn't going to get it done when it has two 1250's sitting on a sheet metal tunnel ram with 640 cid under it. Would rather do it once.
Still vote for the 5" Hemi scoop. Do you have to run the Aero style?
[Re: JERICOGTX]
#1103187
10/29/11 05:42 PM
10/29/11 05:42 PM
Mr.Yuck
Brookeville, Md
Paint your hood top and bottom and the scoop white. That will cool the air charge that comes into the carb. That will make more HP than an aero scoop.
WTH does the paint color have to do with the air going into the carb?
I would think little to none. I guess the air temp from a white or liight colored hood vs a flat black hood would be no more than a few degrees?? It's not pulling air off the hood.
[Re: Gumbydammit]
#1103188
10/29/11 07:16 PM
10/29/11 07:16 PM
408strokerdart
Out West
I'm partial to the pro-stock style scoop that is a bit more squared off to fit the lines of a Dart.
I agree it would probably look better with something that has more squared off features since the Dart lines are boxy. I am looking at everything at this point. Haven't really ruled anything out yet.
[Re: 340SHORTY]
#1103194
10/31/11 07:48 AM
10/31/11 07:48 AM
Posts: 21,067 Niles , Ohio
therocks
Niles , Ohio
340 Shorty that looks kinf of like the one on my 65.Mine sits back further where the hole is though.I bought mine back in like 72.Ill have to see if I can get a pic posted of it.Its been to 120 quite a bit and no problems.Rocky
Chrysler Firepower
[Re: A/MP]
#1103195
10/31/11 08:22 AM
10/31/11 08:22 AM
Mr.Yuck
Brookeville, Md
Obviously not many readers understood what I had posted.. REAL CLEAR unless you are going 150+ that scoop is not providing you with any real HP. IF YOU HAVE A COOLER AIR CHARGE FROM THE AIR TEMP OF THE DAY YOU ARE HELPING YOURSELF TO SOME FREE HP. THINK OF THIS ....YOU WAIT IN THE STAGING LANES FOR PROBABLY 15-30mins. The sun beats down on your hood to the point that you can't comfortably keep your hand on it. Now add the temp increase that the engine creates as the motor runs while you do your burnout and stage. The air temp in the engine compartment is over 170+. Your scoop and hood temps are about 120+. The white paint(gloss)on both sides of the hood will reduce the those temps by minimum 10 o/o. Thats free HP> Enough to get you slightly more than you have. Case in point '65 SS Hemi w/factory scoop 9.01 9.03, 9.01. Same car, same day just 3 hrs. later, no scoop w/white hood 9.02, 9.03,9.03.
What are you saying here? I still don't see how a white hood is going to help your et. If it did every NASCAR and NHRA prostock car would have a white hood. Same with painting the under side white. How is that going to effect anything, it's dark under there. I argee that the sun beating down on a dark hood makes it hotter than a light hood but I don't think it's going to change your et much. You'd need to do back to back tests with the same car, dark hood vs white hood. Your car above ran consistant 9.0's w/o much change w/ both hoods. Now if you're saying his scoop isn't functional I'll agree it's probably not as effective as a "pro-style" scoop...I'll buy that.
