fuel pump painted engine color or not? #1102838
10/27/11 08:58 PM
10/27/11 08:58 PM
Probably going to be putting in a new fuel pump soon into our small block 70 challenger convert. Since the engine is all detailed up, I wanted to know if the fuel pump was attached prior to the engine receiving the paint or was it installed after the engine was painted? I know big blocks had the fuel pump installed prior to paint but I am not sure about the small blocks. I would imagine they would be the same as its big brother.
Re: fuel pump painted engine color or not? [Re: ] #1102839
10/27/11 10:10 PM
10/27/11 10:10 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
No, bare metal
Re: fuel pump painted engine color or not? [Re: ScottSmith_Harms] #1102840
10/27/11 10:12 PM
10/27/11 10:12 PM
ok, so the bare cast alluminum and the cadium plated part of the pump? Sounds like it is time for some RPM on that part then!
Re: fuel pump painted engine color or not? [Re: ] #1102841
10/27/11 10:13 PM
10/27/11 10:13 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Right, the entire assembly was bare as cast, etc. no paint
Re: fuel pump painted engine color or not? [Re: ] #1102842
10/27/11 10:19 PM
10/27/11 10:19 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
v
Re: fuel pump painted engine color or not? [Re: Alaskan_TA] #1102843
10/27/11 10:21 PM
10/27/11 10:21 PM
thanks barry.
Re: fuel pump painted engine color or not? [Re: Alaskan_TA] #1102844
10/27/11 11:51 PM
10/27/11 11:51 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Barry, that pic just reminded me.....The 71 340 I just bought still had that round head nylon push in retainer in the head (the one that holds that paper tag on) but mine didn't have the tag any longer.
Re: fuel pump painted engine color or not? [Re: ScottSmith_Harms] #1102845
10/28/11 12:50 AM
10/28/11 12:50 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Whats with the paper tag? first i've seen
Re: fuel pump painted engine color or not? [Re: ademon] #1102846
10/28/11 01:09 AM
10/28/11 01:09 AM
Crook County, ILL
Mastershake340 Online content
Mastershake340  Online Content
Crook County, ILL
Mike that is a picture from that low mile FY1 Mr Norms T/A that turned up west of here a while back, that Barry documented and made the pictures available on a DVD he sells.
Re: fuel pump painted engine color or not? [Re: Mastershake340] #1102847
10/28/11 01:28 AM
10/28/11 01:28 AM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
Ok, but what's the tag for? What does it all mean???
Re: fuel pump painted engine color or not? [Re: lahatte] #1102848
10/28/11 02:24 AM
10/28/11 02:24 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
never seen one before, some high factory worker forgot to remove it?
Re: fuel pump painted engine color or not? [Re: ademon] #1102849
10/28/11 10:12 PM
10/28/11 10:12 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I do not know what it means either. None of the numbers match up to the engine assembly numbers on the broadcast sheet. One of many small mysteries.......
Re: fuel pump painted engine color or not? [Re: Alaskan_TA] #1102850
10/28/11 10:15 PM
10/28/11 10:15 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
This shows all of the numbers. I bet the small 25 is an inspectors stamp.
Re: fuel pump painted engine color or not? [Re: Alaskan_TA] #1102851
10/28/11 10:17 PM
10/28/11 10:17 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The back side, note that it was installed while the engine paint was still wet. So, it was installed at the Windsor engine assembly plant before the engie was sent to Hamtramck to be installed in a car.
Re: fuel pump painted engine color or not? [Re: Alaskan_TA] #1102852
10/28/11 10:52 PM
10/28/11 10:52 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
It could relate to may things, batch number, inspector, assembly person, etc. Or it could relate to the application similar to part/assembly numbers, TA/AAR, 4 speed/auto trans, etc.
Re: fuel pump painted engine color or not? [Re: ScottSmith_Harms] #1102853
10/29/11 12:54 AM
10/29/11 12:54 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
It's intriguing that the tag stayed on the motor, when it appears that someone installed headers. Wonder if it was some sort of Routing tag or delivery location?
Re: fuel pump painted engine color or not? [Re: Alaskan_TA] #1102854
10/29/11 01:14 AM
10/29/11 01:14 AM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
When was the car built? I wonder if the 147 could refer to a date, as in 14th day, month 7.
Re: fuel pump painted engine color or not? [Re: lahatte] #1102855
10/29/11 02:56 PM
10/29/11 02:56 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
The way its punched out it almost looks like a shipping/routing card, maybe went on the container, rack, and even on a few engines inside the container/rack, doesn't look to me like it has anything to do with the engine itself. Just a wild guess..
Re: fuel pump painted engine color or not? [Re: lahatte] #1102856
10/29/11 03:09 PM
10/29/11 03:09 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Car was built in April. Final assembly date on the engine is Feb. 17, 1970
