Re: My 69 HEMI Charger got paint!!!! :)
[Re: cdp]
#1102695
10/31/11 05:06 PM
10/31/11 05:06 PM
Posts: 9,672 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
Thanks!!! The black sealer came out great....the downside is that its taking forever and beyond to dry I guess Ill just have to wait.... Ill work on another car in the meantime I guess.... Domingo
[Re: domingo]
#1102698
11/03/11 10:11 AM
11/03/11 10:11 AM
Posts: 894 Connecticut, USA
sixty7gtx
Connecticut, USA
How long has the car been in peru?
1967 Plymouth GTX, 1968 HEMI, 4 Spd. Super Bee, 2010 Chrysler 300 Touring,
MOPAR = Machines Of Performance And Racing!!
[Re: 68427vette]
#1102703
11/26/11 06:18 PM
11/26/11 06:18 PM
domingo
EL Master
EL Master
Lima, Peru
The tar sealer is slowly drying....I guess 1 more month till it's completely dry. I will then finish off the paintjob....Im just letting the body sit there until its dry...
In the meantime I have lots of things to restore and get ready to mount on the freshky painted shell once its done!!!
So, I have decided to work on the engine now. I am gonna rebuild the numbers matching HEMI engine. Its going 30 over, I already bought a brand new and balanced rotating assembly: eagle 4,15" stroke crank and stock size rods, and 0.030" over diamond forged pistons. So its gonna be a 477 CID hemi. I got my blueprinted and balanced rotating assembly off Best Machine Racing engines, so I know its done right and ready to drop in!
Im gonna build it with 10,5:1 compression.
The block is really nice and there is no corrossion at all in the water jackets. Looks like new!!! In fact I have never seen a used favtory block as clean as this one-
Now the heads are another story...they had been ported and whoever did the job got a bit carried away so they are junk. Its a shame because the water jacekts on these heads were perfect as well, and they had no cracks at the chambers. The port walls were left too thin after porting though and they cracked.
Oh well....since the original heads are no useable, I just opted to get brand new aluminum heads for it. I gor a great deal on a pair of brand new alum MP eddy heads, and I sent em over to Jeff at Modern Cylinder head. I know these heads are not exact in appearance to the originals (shape of the alterntor boss, some extra ribs or bumps at the end of the head, etc) but they are dimensionally the same and all the stock components bolt on. Really only 1% of the people looking at the engine inside the car would notice, and since its only a bolt on item I'm not sweating it. Its not like Im not gonna miss that correct bump on the end of the head or the correctly shaped alternator boss with 600 HP under my right foot! LOL This is what I got back...
[Re: domingo]
#1102710
03/22/12 09:33 PM
03/22/12 09:33 PM
domingo
EL Master
EL Master
Lima, Peru
Ftre having been working on the body and get it super straight with lots of blocking....here are the final results with a couple coats of basecoat to sort the final details and catch the last few flaws. We are hitting the paint booth on saturday. YOu cna check the full progress step by step here: http://www.facebook.com/1969.hemi.charger
