Duplicating Paint Markings #1102502
10/27/11 12:02 PM
10/27/11 12:02 PM
MD
floyd Offline OP
floyd  Offline OP
MD
Anyone know how markings like this were originally made? Sprayed? Daubed? How would you duplicate these?
Re: Duplicating Paint Markings [Re: floyd] #1102503
10/27/11 12:34 PM
10/27/11 12:34 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Looks like drips?????
if so thats how I would recreate them.
dip something in paint and hold it over the part and let it drip
A coffee stirrer is good to use( they are very thin straws )
maybe a pencil eraser dipped in paint and 'dab' it there
Re: Duplicating Paint Markings [Re: floyd] #1102504
10/28/11 06:31 AM
10/28/11 06:31 AM
www.mmcdetroit.com
MMC Detroit Offline
MMC Detroit  Offline
www.mmcdetroit.com
Those marks are made with paint daubers.
MMC/ ICCA Detroit. The Motor City or where ever there is Mopars
Re: Duplicating Paint Markings [Re: floyd] #1102505
10/28/11 08:36 AM
10/28/11 08:36 AM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
You can't duplicate them and make them look natural. They will always look like someone tried to duplicate them and not look original.
Re: Duplicating Paint Markings [Re: MMC Detroit] #1102506
10/28/11 10:02 AM
10/28/11 10:02 AM
MD
floyd Offline OP
floyd  Offline OP
MD
What does a dauber look like? A big q-tip type thing?
Re: Duplicating Paint Markings [Re: RoadRunnerJD] #1102507
10/28/11 10:55 AM
10/28/11 10:55 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
well...how were they put on there originally then? when the cars were new, did the paint dabs all look "duplicated and not original"?
**Photobucket sucks**
Re: Duplicating Paint Markings [Re: floyd] #1102508
10/28/11 12:12 PM
10/28/11 12:12 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
get some (empty) small travel size shampoo bottles and stuff some open cell foam into it after filling with a small amount of thinned enamel paint.
Trick is to get the foam stuffed in there with a small amount hanging out (that should be trimmed to a square or circle as needed, depending on mark) and have the right paint consistency.
Practice on scraps until you can quickly dab the foam and ger the right paint dribble. Try having about 1/4" of foam protruding above the bottle top, that seems to be the right amount. Thinning is tricky, it does not take much.
Re: Duplicating Paint Markings [Re: srt] #1102509
10/28/11 12:28 PM
10/28/11 12:28 PM
MD
floyd Offline OP
floyd  Offline OP
MD
Thanks - I may give that a try.
Re: Duplicating Paint Markings [Re: floyd] #1102510
10/28/11 02:06 PM
10/28/11 02:06 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
http://www.franticstamper.com/ranger-daubers.htm
http://www.discountschoolsupply.com/Product/ProductDetail.aspx?product=751
Try searching for refillable bingo markers or duabers. Or look as Micheals or some type of craft store.
Re: Duplicating Paint Markings [Re: NV69B7RR] #1102511
10/29/11 01:37 AM
10/29/11 01:37 AM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
Ok, on that Franticstamper site, which colors do I need to correctly mark all the spots on my 71 383 cuda?
Re: Duplicating Paint Markings [Re: floyd] #1102512
10/29/11 12:16 PM
10/29/11 12:16 PM
St Louis, Missouri
Runnin74 Offline
Runnin74  Offline
St Louis, Missouri
Re: Duplicating Paint Markings [Re: RoadRunnerJD] #1102513
10/29/11 03:02 PM
10/29/11 03:02 PM
Why can't you? Unless you are trying to be deliberate, gravity and paint will flow the same today as it did forty years ago. Magic robots didn't apply those markings at the factory. People did. It was an inspection mark to indicate that someone checked a particular function or service to a part. Apply it like they did and it will look original again.
Re: Duplicating Paint Markings #1102514
10/29/11 05:37 PM
10/29/11 05:37 PM
MD
floyd Offline OP
floyd  Offline OP
MD
I used aeresol-can paint sprayed into a dixie cup (nice and thin) and daubed it on with a fluffed up q-tip. Good enough for me. Thans for the suggestions.
Re: Duplicating Paint Markings [Re: floyd] #1102515
10/30/11 11:46 AM
10/30/11 11:46 AM
My Garage / Museum
idrivevintage Offline
Chrysler Plant
Chrysler Plant
My Garage / Museum
Looks nice!
