70 383 Magnum a 3 bolt or 1 bolt cam ? #1101920
10/26/11 02:34 PM
10/26/11 02:34 PM
Blairsden, CA
Triggerfish Offline OP
Blairsden, CA
Did stock 383 magnums come with 1 bolt or 3 bolt cams? I'm
going to re-cam the 70 383 in my 71 Power Wagon for low end
torque & didn't want to pull the timing cover off to find out.
I've heard the factory installed whatever they had on the line,
so not all hp motors got the 3 bolt cams??
Re: 70 383 Magnum a 3 bolt or 1 bolt cam ? [Re: Triggerfish] #1101921
10/26/11 02:40 PM
10/26/11 02:40 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
No 383 ever came with a 3-bolt cam, the only Wedge to get one was the 440-6.
Re: 70 383 Magnum a 3 bolt or 1 bolt cam ? [Re: John_Kunkel] #1101922
10/26/11 02:48 PM
10/26/11 02:48 PM
Blairsden, CA
Blairsden, CA
Thanks John & that makes it much simpler. I was considering an Engle
K54 or Hughes ah1928bl. Crane makes Summit Racing's cams & they
have one similar to the Engle for only $54. Any input on these choices?
thanks.
Re: 70 383 Magnum a 3 bolt or 1 bolt cam ? [Re: John_Kunkel] #1101923
10/26/11 02:53 PM
10/26/11 02:53 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
If you're putting in a new cam, that project should surely include a high-quality timing chain set also, so just make sure they match.
Re: 70 383 Magnum a 3 bolt or 1 bolt cam ? [Re: Fury Fan] #1101924
10/26/11 02:57 PM
10/26/11 02:57 PM
Blairsden, CA
Blairsden, CA
I'll get a Cloyes double roller & will replace the water pump, too.
Thinking of the Summit cam cause the price is great & they're local,
but really trust Hughes & Engle's mopar grinds.
Re: 70 383 Magnum a 3 bolt or 1 bolt cam ? [Re: Triggerfish] #1101925
10/27/11 12:24 AM
10/27/11 12:24 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Nice truck!!!
Engle user here, multiple times, very happy with 'em.
Re: 70 383 Magnum a 3 bolt or 1 bolt cam ? [Re: John_Kunkel] #1101926
10/27/11 12:33 AM
10/27/11 12:33 AM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
only 2 motors ive seen with 3 bolt cam gear factory are 426 hemi and 63/64 426 max wedge
MOPAR OR NO CAR
Re: 70 383 Magnum a 3 bolt or 1 bolt cam ? [Re: Triggerfish] #1101927
10/27/11 12:37 AM
10/27/11 12:37 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
If you have an HP, I'm not sure that a cam change is needed. If it all or near stock, then the OEM cam is about right. I had a long conversation w/ Scott Brown a few years back about doing a custom grind for a 383 Bee. The car was #'s matching and I didn't plan on changing much, if anything. I was going to throw in a new chain as it had some slop, figured I'd swap the cam.
His conclusion was that he might get me 10-15 HP at the most and maybe a little more torque, but with the cost, it was hard to justify. He was honest enough to talk me out of handing him any money for that one.
What are your specs? That truck has a lot of weight to get moving. Big cam might hurt it pretty bad.
Re: 70 383 Magnum a 3 bolt or 1 bolt cam ? [Re: Triggerfish] #1101928
10/27/11 02:58 AM
10/27/11 02:58 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
If your putting a timing chain & gears in it really doesn't matter whats in there now, as long as the cam & gears set matches.... Use what you feel is the better design....
Re: 70 383 Magnum a 3 bolt or 1 bolt cam ? [Re: hemigod426] #1101929
10/27/11 03:07 AM
10/27/11 03:07 AM
I've had several original 426 M.W.,1963 415 HP and 1964 425 HP. no three bolt cams in them from the factory
Re: 70 383 Magnum a 3 bolt or 1 bolt cam ? [Re: Triggerfish] #1101930
10/27/11 03:28 AM
10/27/11 03:28 AM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
Sweet truck!
Re: 70 383 Magnum a 3 bolt or 1 bolt cam ? [Re: hemigod426] #1101931
10/27/11 10:28 AM
10/27/11 10:28 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
1970 and 1971 440-6pk would have come with a 3 bolt cam.
Re: 70 383 Magnum a 3 bolt or 1 bolt cam ? [Re: JohnRR] #1101932
10/27/11 10:45 AM
10/27/11 10:45 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
1970 and 1971 440-6pk would have come wit ha 3 bolt cam.
and with same specs than the 440 HP I think... right ? only diff from these is the 3 bolts setup
Re: 70 383 Magnum a 3 bolt or 1 bolt cam ? [Re: NachoRT74] #1101933
10/27/11 10:47 AM
10/27/11 10:47 AM
U.S.S.A.
U.S.S.A.
No , the 440 4 bbl had lower compression ratio than a 6pk , 9.7 ...
Re: 70 383 Magnum a 3 bolt or 1 bolt cam ? [Re: JohnRR] #1101934
10/27/11 11:10 AM
10/27/11 11:10 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I meant the cam specs, not the engine specs
Re: 70 383 Magnum a 3 bolt or 1 bolt cam ? [Re: NachoRT74] #1101935
10/27/11 11:15 AM
10/27/11 11:15 AM
U.S.S.A.
U.S.S.A.
They are supposed to be ....
Re: 70 383 Magnum a 3 bolt or 1 bolt cam ? [Re: 1_WILD_RT] #1101936
10/27/11 12:08 PM
10/27/11 12:08 PM
Blairsden, CA
Blairsden, CA
Thanks Randy & I was thinking of switching, but Summit's cam is only $54 & that's hard to beat & made by Crane, too. But if I ever decide to swap the 383 for my 451, maybe a 3 bolt setup would be a better selling factor if I decide to turn it loose. But being in a truck, I think the one bolt would be fine.
Hope you've been able to enjoy some top down crusin w/ the Chally.
Re: 70 383 Magnum a 3 bolt or 1 bolt cam ? [Re: JohnRR] #1101937
10/27/11 12:23 PM
10/27/11 12:23 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 70 383 Magnum a 3 bolt or 1 bolt cam ? [Re: Triggerfish] #1101938
10/27/11 01:06 PM
10/27/11 01:06 PM
U.S.S.A.
U.S.S.A.
The number of bolts in the cam has to do with the valve action of the cam.
I really don't think a 1 bolt vs a 3 bolt would be a deal breaker in selling an engine .
Re: 70 383 Magnum a 3 bolt or 1 bolt cam ? [Re: JohnRR] #1101939
10/27/11 01:24 PM
10/27/11 01:24 PM
Blairsden, CA
Blairsden, CA
Thanks John. Summit's 6400 cam has a power band of 1500 - 5K, lift @ .050 is 214 int/224 ex & advertised duration of 272/282. Lift is 442/465 & has a 112 centerline. Do you think this would be a good
cam for the truck? (3.55's w/ 35" tires.)
