Mopar Techs: Problem with 06 300C, dies after fueling #1101825
10/26/11 03:46 AM
10/26/11 03:46 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
My moms car (06 300C) has a problem that nobody has been able to diagnose and is getting worse.
The problem is after filling the fuel tank, the car will almost immediately die when started back up. Today it died 3 times after filling up. Got down the road a few miles, and it died repeatedly in traffice. The only time the car has died is after filling up, only when the tank is full or almost full. I can pump the throttle and it will start, but idle very rough. Clean it out and it will be ok, may die again, may not. It was pretty nuts in traffice trying to keep it running.
After the fuel gauge goes down a hair the problem goes away till the next time the car is filled.
It has had this problem for going on 2 years, but today it was very bad.
Ive had the car in two shops (one a chrysler dealership) and they can find anything wrong. Apparently it isnt throwing any codes.
Any ideas?
Thanx in advance for any help or advice.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Mopar Techs: Problem with 06 300C, dies after fueling [Re: Von] #1101826
10/26/11 08:08 AM
10/26/11 08:08 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
sounds like water in the tank.after the level goes down it sloshes around enough where its not consintrated at the pickup.
Re: Mopar Techs: Problem with 06 300C, dies after fueling [Re: Von] #1101827
10/26/11 09:11 AM
10/26/11 09:11 AM
ill
dennismopar73 Offline
ill
fuel return issue at the pump poss = bad fuel pump
Re: Mopar Techs: Problem with 06 300C, dies after fueling [Re: dennismopar73] #1101828
10/26/11 12:24 PM
10/26/11 12:24 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
gas cap?
Re: Mopar Techs: Problem with 06 300C, dies after fueling [Re: d-150] #1101829
10/26/11 12:28 PM
10/26/11 12:28 PM
P
Paul_Fancsali Offline
P
Bet on a Fuel filter or pump problem. Had a Buick that did a similar thing and it was the pump. Pressure test pump and make sure your evap system is functioning properly. Try cracking the cap and see if it does it Check engine light should come on
Re: Mopar Techs: Problem with 06 300C, dies after fueling [Re: d-150] #1101830
10/26/11 12:44 PM
10/26/11 12:44 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
gas cap?
good call,but too simple
Re: Mopar Techs: Problem with 06 300C, dies after fueling [Re: bonefish] #1101831
10/26/11 01:37 PM
10/26/11 01:37 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
I did some searching and it appears this is a sort of common problem. Most likely a problem in the evap system, either a valve or canister. Valve is servicable, canister is not....new tank if the canister is plugged.
Re: Mopar Techs: Problem with 06 300C, dies after fueling [Re: Von] #1101832
10/26/11 04:11 PM
10/26/11 04:11 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Von there may have been a TSB about that. I left the Dodge dealer in March this year but might be able to get at the service bulletins to check them. I have seen a few problems like this over the years so let me see what I can find out. Ron
Re: Mopar Techs: Problem with 06 300C, dies after fueling [Re: 383man] #1101833
10/26/11 05:34 PM
10/26/11 05:34 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
Hello! Have seen this. Dealer should know about this problem also. We've found the roll-over valve bad. This is only serviceable by replacing the tank unfortunately. Ck for fuel in the vent hose going to the canister, with a full tank. If so, your gonna have to replace tank. I'm assuming this is the 5.7? Hope this helps! Jeff
Re: Mopar Techs: Problem with 06 300C, dies after fueling [Re: 1969RR] #1101834
10/26/11 07:30 PM
10/26/11 07:30 PM
upstate NY 12839
TMBOOTS Offline
TMBOOTS  Offline
upstate NY 12839
Sounds expensive!!!My 05 300C is acting the same way-never anything easy. GREAT that you could share this info. Tom
Re: Mopar Techs: Problem with 06 300C, dies after fueling [Re: TMBOOTS] #1101835
10/26/11 07:33 PM
10/26/11 07:33 PM
Berwyn, IL
Moparlar Offline
Moparlar  Offline
Berwyn, IL
My wifes caravan was doing that and they had to replace the tank. Luckily for me it was done under warranty.
LArry
