Wiring Harness clean-up? #1101615
10/25/11 07:13 PM
10/25/11 07:13 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Dash wiring harness appears to be in good shape...but is flithy. Will definetly ohm out and test....but what is a good method to clean it up?
Simple green??
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Wiring Harness clean-up? [Re: JMCFAN] #1101616
10/25/11 08:50 PM
10/25/11 08:50 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Simple green is corrosive.
Re: Wiring Harness clean-up? [Re: astjp2] #1101617
10/25/11 09:17 PM
10/25/11 09:17 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
why I am asking....?
Re: Wiring Harness clean-up? [Re: astjp2] #1101618
10/25/11 09:52 PM
10/25/11 09:52 PM
I used Goop and Gojo hand cleaner (the ones without grit).
They worked great on my harnesses in the '63 Dodge.
Re: Wiring Harness clean-up? [Re: JMCFAN] #1101619
10/26/11 09:16 AM
10/26/11 09:16 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I used a pressure washer, worked great. I sprayed some degreaser on them first and laid them out in my driveway and blasted them clean. Then WD 40 them.
Re: Wiring Harness clean-up? [Re: Challenger 1] #1101620
10/26/11 10:40 PM
10/26/11 10:40 PM
owensboro, ky
rallye73 Offline
rallye73  Offline
owensboro, ky
I washed my dash harness in the dishwasher. Worked pretty good too.
Re: Wiring Harness clean-up? [Re: rallye73] #1101621
10/26/11 11:53 PM
10/26/11 11:53 PM
MO
cdp Offline
cdp  Offline
MO
Enamel reducer on a rag works well. Cleans them up instantly.
If you have paint on them, I've watched a buddy use spray stripper, then scrub with a cut down paint brush, then hoses it off many times. Followed by enamel reducer.
Did in on an original harness for a 429CJ Torino that went to Barrett Jackson.
