Horsepower gains #1101519
10/25/11 05:57 PM
10/25/11 05:57 PM
Cincinnati Oh
fasthawk6 Offline OP
Cincinnati Oh
I have heard rumors of Hp gains going to a titiaum valve train and roller cam bearings. Is this true and how much would someone expect to gain.
Re: Horsepower gains [Re: fasthawk6] #1101520
10/25/11 06:35 PM
10/25/11 06:35 PM
AndyF Online content
AndyF  Online Content
Somewhere around the 1000 hp mark you'll probably need to start using stuff like that.
Re: Horsepower gains [Re: AndyF] #1101521
10/25/11 06:55 PM
10/25/11 06:55 PM
Cincinnati Oh
Cincinnati Oh
The motor is a 436 on a 325 shot of nos and runs 5.40s at 130mph at 3100lbs. The promblem is you have to run a factory valve angle head in the class he runs and was told by a TEA { i think it was them } he would pick up about 70 hp. I never beleive what i am told by sales people so i thought i could get some good answers here.
Re: Horsepower gains [Re: fasthawk6] #1101522
10/25/11 07:21 PM
10/25/11 07:21 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Not buying 70HP
Re: Horsepower gains [Re: camastomcat] #1101523
10/25/11 07:32 PM
10/25/11 07:32 PM
Cincinnati Oh
Cincinnati Oh
Not buying 70HP
Thats what i think so i am hopping some engine builders will respond.
Re: Horsepower gains [Re: fasthawk6] #1101524
10/25/11 08:11 PM
10/25/11 08:11 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
The cam bearings might give you nothing. The way I see the Ti valves is you don't gain anything from them but if you don't have them you are losing something. Maybe not power but valve train stability.
Certainly not worth the $$ spent.
Re: Horsepower gains [Re: Diablo] #1101525
10/26/11 10:38 AM
10/26/11 10:38 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
The potential HP is primarily from the reduced mass allowing the motor to rev higher....but that is provided you have the airflow in your heads and cam for the motor to take advantage of it. Putting it another way, is valvetrain mass the main limiting factor now that's holding your combo back? Or is it airflow?
The Valvetrain itself doesn't give you very much within the original powerband RPM range....other than the reduction of mass, similar to the beneficial effects of a lighter bobweight. so providing proportionally higher head flow and cam is the key, so on a motor like yours raising the powerband to peak 500-600 rpm higher could easily be 70hp. The next question would be if your block can withstand the additional power and heat of the higher Peak torque RPM.
WIZE
In Car:
Re: Horsepower gains [Re: Streetwize] #1101526
10/26/11 03:26 PM
10/26/11 03:26 PM
Cincinnati Oh
Cincinnati Oh
Yes the heads a getting switched and block is aftermarket and also a cam change. I was just trying to figure out if what they said is true. Now he will have to figure out if the cost is worth or not.70 hp is a pretty good pickup while still using a factory valve angle head after all other work is done.
Re: Horsepower gains [Re: fasthawk6] #1101527
10/26/11 03:45 PM
10/26/11 03:45 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
The cost is very high for what you plan on doing. That type of thing is Pro Stock/Comp type stuff. Some of the high end Super Stock guys I know are running roller cam bearings.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: Horsepower gains [Re: sixpackbee] #1101528
10/26/11 04:09 PM
10/26/11 04:09 PM
Cincinnati Oh
Cincinnati Oh
In the heads up classes he runs in every little bit helps.He runs in a limted 8.5 class which is jet limited and a outlaw 8.5 class.The motor is just about tapped out now so looking for some hp in other areas. Also looking at going to a dominator carb.I know its a brand x but thats about the only way to go in these headsup classes for weight unreal 60fts for stock sups plus extra parts in case of a wreck.
