what is positive wire on coil with electronic ignition #1101458
10/25/11 03:08 PM
10/25/11 03:08 PM
DELAWARE
68moparmike Offline OP
DELAWARE
i was having problems with my car burning coils up not starting so i unhooked the original positive wire to the coil and hooked up a jumper dirrectly to the battery car starts and runs but when i take of the positve wire off the car continues to run. so i turned key off and car shuts off and starts back upwith out a wire on the positive side of coil...i guess my question is what is the positve wire for?
Re: what is positive wire on coil with electronic ignition [Re: 68moparmike] #1101459
10/25/11 03:15 PM
10/25/11 03:15 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
When you say you removed the positive wire did you remove the one from the battery you installed also?
Re: what is positive wire on coil with electronic ignition [Re: stumpy] #1101460
10/25/11 05:01 PM
10/25/11 05:01 PM
DELAWARE
DELAWARE
yes as of right now there is no wire on the coils positive side and car still starts
Re: what is positive wire on coil with electronic ignition [Re: 68moparmike] #1101461
10/25/11 05:46 PM
10/25/11 05:46 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
Thats fantastic!
Re: what is positive wire on coil with electronic ignition [Re: 68moparmike] #1101462
10/25/11 05:51 PM
10/25/11 05:51 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
Thats fantastic! Could you by chance have the + wire to the negative side? Coil needs juice to set up the field, the ground colapses the field stepping up the secondary voltage to zap the plug. If there is no electricity (6-12V) to the coil, im stumped. Now a CD ignition sends 300V to the coil of the bat, are you running one, maybe hooked up wrong?
Re: what is positive wire on coil with electronic ignition [Re: pishta] #1101463
10/25/11 05:56 PM
10/25/11 05:56 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: what is positive wire on coil with electronic ignition [Re: abodyjoe] #1101464
10/25/11 06:44 PM
10/25/11 06:44 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
the diagram looks right but as stated above juice has to be supplied to the coil. even if your wiring was reversed without a wire on the other side of the coil the path is broken. is this a 'trick or treat'?
Re: what is positive wire on coil with electronic ignition [Re: mikemee1331] #1101465
10/25/11 06:55 PM
10/25/11 06:55 PM
DELAWARE
DELAWARE
ok thanks for the diagram joe i think i found the problem the wire coming from key switch was shorted out...thanks everyone...no now i tryed to start it without the wire hooke up and wont start
