Using a slide hammer on fender after filler work? #1101281
10/25/11 01:09 AM
10/25/11 01:09 AM
U.S.
basik Offline OP
basik  Offline OP
U.S.
Is it ok to use a slide hammer on the edge of a fender (at the fender/door gap) after the fender's filler work has all been done? Or will the movement mess up the filler work?
Re: Using a slide hammer on fender after filler work? [Re: basik] #1101282
10/25/11 01:29 AM
10/25/11 01:29 AM
Jacksonville Florida
elitecustombody Offline
As long as filler don't crack.Use masking tape
Re: Using a slide hammer on fender after filler work? [Re: elitecustombody] #1101283
10/25/11 02:19 AM
10/25/11 02:19 AM
U.S.
basik Offline OP
basik  Offline OP
U.S.
Right now all of the filler is painted over with epoxy. If I see any cracks form I guess I'll have to go ahead and start over in that area. I should have made sure everything was perfect with the metal alignment before I started filler work.
Re: Using a slide hammer on fender after filler work? [Re: basik] #1101284
10/25/11 05:00 PM
10/25/11 05:00 PM
try using mixing stick to bring out the fender, if you have hard plastic wedges, they work great for aligning panels,
Re: Using a slide hammer on fender after filler work? [Re: elitecustombody] #1101285
10/25/11 10:42 PM
10/25/11 10:42 PM
Greenville, N.C.
BarrsRestoration Offline
Greenville, N.C.
Agreed. Sometimes the impact shock on the backside of sheet metal that has filler can cause it to separate from the metal, leaving no cracks or other visible signs. At least not for a while.
It really depends on how thick the filler is where the impact happens, and how hard the impact is.
