better handling #1100733
10/24/11 01:33 PM
10/24/11 01:33 PM
85086
moparpollack Offline OP
Lil Herman
Lil Herman
85086
What would be the better set up for handling on a 70 Dart?
1 1.03 t-bars with sway bars front and rear, kyb shocks, stock rear springs.
2 Stock t-bars with sway bars front and rear, kyb shocks, stock rear springs.
Both set ups would be run with 17" wheels 225/45/17 tires.
Thanks!
Re: better handling [Re: moparpollack] #1100734
10/24/11 01:43 PM
10/24/11 01:43 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Thanks!
#1 but it will be a rougher ride.
Upgrading to Hotchkis Bilstein shock would be a big improvement over KYB's too. But if you are doing other suspension work (bushing, ball joints) the T-bars aren't much more time and labor. You can go back and upgrade the shocks later and it's an easy install.
Close call between T-bars (~$250 more) and Bilsteins ($400-$150 for KYB's more). But I'd go with the T-bars.
Re: better handling [Re: autoxcuda] #1100735
10/24/11 02:48 PM
10/24/11 02:48 PM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
kyb shocks suck. I switched to the eldebrock shocks, they work much better, .99 tbars, ff swaybar, hd rear springs.
-Daty
Re: better handling [Re: autoxcuda] #1100736
10/24/11 04:48 PM
10/24/11 04:48 PM
85086
Lil Herman
Lil Herman
85086
Thanks!
I already have the shocks I was thinking that the bars would be more headache than cure. The reason I ask this is matching the spring rates so the car works. Hotchkiss leaves the t-bars out of their package so I was thinking a higher rate wasn't as important as to having matched stock rates.
Re: better handling [Re: moparpollack] #1100737
10/24/11 05:40 PM
10/24/11 05:40 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Thanks!
They now sell T-bars. I don't think they put them in the kit because of cost and buyer preference. There test cars (Yellow T/A, Blue RR) all have .99 or bigger T-bars.
The adjustable rear sway bar that Hotchkis and Helwig sells will allow you fine tuning of the front a rear balance.
Re: better handling [Re: autoxcuda] #1100738
10/24/11 05:49 PM
10/24/11 05:49 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
Torsion bar needs will widely vary based on balance of the car, BB, SB, A-body, B-body, etc. The 1.03 are a good all around rate as it matches up to the compression and rebound settings of the Bilstein shock they offer. You go to a bigger bar you run the risk of over working the shock and hurting it.
At that point, as we do on our car which has 1.12 bars in it, you must consider going to more race type adjustable mono-tube shock.
1968 Pro-Touring Dodge Charger
*2011 Optima Ultimate Street Car Challenge Invitee
http://www.popularhotrodding.com/features/1203phr_1968_dodge_charger/index.html
Post deleted by moparts [Re: autoxcuda] #1100739
10/24/11 05:55 PM
10/24/11 05:55 PM
Re: better handling #1100740
10/24/11 06:01 PM
10/24/11 06:01 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
you want better handling? take your hands off the beer, and put em both on the wheel. just an idea
You registered just today and that's the most constructive advice you have to offer?
Re: better handling [Re: Viol8r] #1100741
10/24/11 06:10 PM
10/24/11 06:10 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I run Bilsteins with 1.14 T-bars in an A-body (higher rate than B-body). Seem to be fine track and street.
More shock control that KYB's with .99's.
Re: better handling [Re: moparpollack] #1100742
10/24/11 11:09 PM
10/24/11 11:09 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
1. Throw the KYB's away
2. Make sure the garbage man takes them away
3. nothing the others have posted is wrong and all will help, but not as much #1 above.
4. Unless you have numbers on yoour doors on weekends, you are likely over thinking this, but you'll soon discover this on your own.
Re: better handling [Re: jcc] #1100743
10/25/11 10:27 PM
10/25/11 10:27 PM
MarkZ Online boogie
Worthy
MarkZ  Online Boogie
Worthy
Have you installed frame ties? I went though upgrading shocks, springs, and sway bars, and the biggest difference is when I welded ties in. Night and day...
Re: better handling [Re: MarkZ] #1100744
10/25/11 10:41 PM
10/25/11 10:41 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
However, could it have been "day and night"?
I mean, if one installed "welded ties" first, the difference noticed without upgraded shocks, springs, and sway bars might not have been very significant.
Re: better handling [Re: autoxcuda] #1100745
10/25/11 10:43 PM
10/25/11 10:43 PM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
Those Hotchkis kits are pretty pricey. Is there a good source for them at a better price?
Re: better handling [Re: lahatte] #1100746
10/26/11 10:18 AM
10/26/11 10:18 AM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Have you ever heard of the Green Brick? Might want to check it out.
Re: better handling [Re: moparpollack] #1100747
10/26/11 01:34 PM
10/26/11 01:34 PM
Sante Fe Springs, CA
Hotchkis Offline
Hotchkis  Offline
I already have the shocks I was thinking that the bars would be more headache than cure. The reason I ask this is matching the spring rates so the car works. Hotchkis leaves the t-bars out of their package so I was thinking a higher rate wasn't as important as to having matched stock rates.
MoparPollack - We leave the torsion bars out of the TVS because we know that not everyone wants or needs to replace their T-bars. Plus we sell all the parts in the TVS separately. With that said, the TVS kit is a great kit with some big gains over the typical stock suspension.
If you're starting from scratch on a Dodge Dart you should start with leaf springs and T-bars. Then upgrade shocks and sway bars. Some weld-in subframe connectors are also a big help over stock. You never realize how flexible the car is until you have a set of weld-in connectors. They are much better than bolt-in connectors, especially if you drive your car hard.
Re: better handling [Re: Hotchkis] #1100748
10/26/11 01:50 PM
10/26/11 01:50 PM
85086
Lil Herman
Lil Herman
85086
I looked at it this way:
1 Springs/torsion bars are matched from the factory.
2 Matched sway bars would work better with matched factory springs.
3 Messing with one end before the other would make it worse.
4 The car already has frame connectors makes it much more ridgid.
5 Was confused why the torsion bars were left out as if a high rate spring was really needed.
Re: better handling [Re: moparpollack] #1100749
10/26/11 02:17 PM
10/26/11 02:17 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
IMO frame connectors should be #1, they do make a huge difference.
Re: better handling [Re: Challenger 1] #1100750
10/26/11 02:21 PM
10/26/11 02:21 PM
85086
Lil Herman
Lil Herman
85086
That's why I did it first.
Re: better handling [Re: moparpollack] #1100751
10/26/11 04:28 PM
10/26/11 04:28 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Wellllll, the factory rates are somewhat matched, but not from a performance handling perspective so much as a cost, comfort, safety perspective. The factory set these cars up to understeer like a pig because when an inexperienced driver gets in over their head and the car is sliding, they step on the brakes to slow everything down and regain control. Additionally, what was percieved as comfort and performace from a suspension system 40 years ago has changed compared to those same consumer evaluations today.
You are right about messing with one end before the other. Stepping up the wheel rates at one end too much will cause that end to slide first. Too much front t-bar/s-bar, the nose pushes. Too much rear leaf spring/s-bar, the rear slides.
For setting up an A body, I'd do whatever autoxcuda says. His car is more dialed in than the average bear's.
Re: better handling [Re: moparpollack] #1100752
10/26/11 08:15 PM
10/26/11 08:15 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Lots of good advice already!
Bigger T-bars would be high on the list. Remember, if it bottoms, spring rate goes to infinity...massive understeer.
Some kind of zero-flex front swaybar links are really a great upgrade -- unreal how much they help 'turn-in'.
Frame connex / torque boxes also rate high.
KYBs, as mentioned, are in the $9.99 'Monro-Matic' league. Bilsteins are excellent, but my personal preference is still the classic Koni adjustables. While no longer sold in the US, you might find 'em down under; my last set came from France.
Be sure any rear swaybar is frame, not axle, hung. If not adjustable, start small -- with a light engine, it is amazing how easy it is to make an A-body into a Corvair / early Porsche!
While more "steering" than "suspension", K-member reinforcements help, or FFI's new bolt-in lower pitman support bearing kit (designed by....;-> ). Also consider Pedders urethane offset upper control arm bushings (also Aussie).
Rick
