Re: Radio antenna on fiberglass fender
[Re: 70duster340]
#1100310
10/23/11 11:24 PM
10/23/11 11:24 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Plug the hole & move the antenna... Either on the rear quarter or on the roof.. You could try a hotrod style hidden antenna in the headliner but generally the reviews aren't good....
[Re: 70duster340]
#1100317
10/23/11 11:59 PM
10/23/11 11:59 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Leave it there but don't use it, try one of the hotrod style hidden antennas, Hirshman makes one of the best..Check the link... http://www.ebay.com/itm/HIRSCHMANN-Hidde...#ht_3109wt_1141It won't work as well as a well executed standard ground plane style antenna but..
[Re: 70duster340]
#1100319
10/24/11 11:50 AM
10/24/11 11:50 AM
Posts: 1,822 Colorado
denfireguy
Colorado
Take a roll of alluminum duct sealer tape (about 4inches wide). Take the backing off and run a strip as far as you can reach to the front of the car to the door opening under the fender. Take another strip and run it from bottom of the fender around the antenna base. Mount the antenna on the foil strips. Will work well on FM, not so well on AM. When you are done, find a weak station on AM near 1400 Khz and peak the antenna tune on the radio. Antenna Specialists and Larsen sold foil pads for two way radio antennas for fiberglass. They are not big enough for AM radio. What I described is bigger than their pads but still really not big enough to totally solve the problem. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
Re: Radio antenna on fiberglass fender *DELETED*
[Re: dennismopar73]
#1100321
10/25/11 01:11 AM
10/25/11 01:11 AM
Posts: 70,126 Here
DirectSubjection
Tacohead. The First and Only
Here
Post deleted by DirectSubjection
Ride eternal, shiny and chrome
[Re: DirectSubjection]
#1100322
10/25/11 08:56 PM
10/25/11 08:56 PM
denfireguy
Colorado
Find it hard to believe that will work. There is no electrical theory cited in the ad and I know of none that would apply. And for $50 american, I don't think I want to even try it.
#1100324
10/26/11 09:23 AM
10/26/11 09:23 AM
Posts: 2,177 ill
dennismopar73
ill
what you seen in the video is an electro magnet,,would work on some applications, but not a radio that receives a signal, what i told him to do is his fix for no ground on fiberglass fenders, quick easy and under dash ,never see it if done correct will work better, as with all devices , it will all ways search for the closes ground. ![](/ubbthreads/images/graemlins/Twocents.gif)
