Radio antenna on fiberglass fender #1100309
10/23/11 10:52 PM
10/23/11 10:52 PM
70duster340 Offline OP
Has anybody ever done this? If so, how did you ground the antenna? Both the front fenders on my Duster are fiberglass, and it already has an antenna mounted from the previous owner. However, the radio never did work when I bough the car.
Anybody have any tips or ideas?
Re: Radio antenna on fiberglass fender [Re: 70duster340] #1100310
10/23/11 11:24 PM
10/23/11 11:24 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Plug the hole & move the antenna... Either on the rear quarter or on the roof.. You could try a hotrod style hidden antenna in the headliner but generally the reviews aren't good....
Re: Radio antenna on fiberglass fender [Re: 1_WILD_RT] #1100311
10/23/11 11:31 PM
10/23/11 11:31 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
run a ground wire..
I am truckless..
Re: Radio antenna on fiberglass fender [Re: 340SHORTY] #1100312
10/23/11 11:33 PM
10/23/11 11:33 PM
I was thinking of that, Shorty. But, how do I attach the ground wire?
Sorry, but I'm not feeling too inventive right now, so any help is greatly appreciated!
Re: Radio antenna on fiberglass fender [Re: 340SHORTY] #1100313
10/23/11 11:35 PM
10/23/11 11:35 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
run a ground wire..
The deal is you want the antenna surrounded by what is called the ground plane.... Not just grounded to the body but actually surrounded by a ground plane..
Re: Radio antenna on fiberglass fender [Re: 1_WILD_RT] #1100314
10/23/11 11:46 PM
10/23/11 11:46 PM
Please explain what a ground plane is?
Re: Radio antenna on fiberglass fender [Re: 70duster340] #1100315
10/23/11 11:49 PM
10/23/11 11:49 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Re: Radio antenna on fiberglass fender [Re: 1_WILD_RT] #1100316
10/23/11 11:55 PM
10/23/11 11:55 PM
OK, I see. I was hoping to keep the antenna where it is, as I prefer the look of it.
Re: Radio antenna on fiberglass fender [Re: 70duster340] #1100317
10/23/11 11:59 PM
10/23/11 11:59 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Leave it there but don't use it, try one of the hotrod style hidden antennas, Hirshman makes one of the best..Check the link...
http://www.ebay.com/itm/HIRSCHMANN-Hidde...#ht_3109wt_1141
It won't work as well as a well executed standard ground plane style antenna but..
Re: Radio antenna on fiberglass fender [Re: 1_WILD_RT] #1100318
10/24/11 08:36 AM
10/24/11 08:36 AM
Palmyra, NY
63stabamatic Offline
Palmyra, NY
This has been a problem for two-way radios on ambulances with fiberglass rears. On those the frequency is higher and easier to do with metal plates or 4 wires going out horizontally 90 degrees apart. It's difficult to get enough ground plane for this frequency, especially AM, FM band is a little easier. I would run a 1 inch wide or larger ground braid from the antenna mount, (ground), to the closest metal part of the body, shouldn't be that far. Try it and see what happens. Depending on the radio you sometimes have to tune the antenna at the radio for maximum signal, usually a small trimmer near the antenna connector, sometimes it's behind one of the knobs.
Re: Radio antenna on fiberglass fender [Re: 70duster340] #1100319
10/24/11 11:50 AM
10/24/11 11:50 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Take a roll of alluminum duct sealer tape (about 4inches wide). Take the backing off and run a strip as far as you can reach to the front of the car to the door opening under the fender. Take another strip and run it from bottom of the fender around the antenna base. Mount the antenna on the foil strips. Will work well on FM, not so well on AM. When you are done, find a weak station on AM near 1400 Khz and peak the antenna tune on the radio.
Antenna Specialists and Larsen sold foil pads for two way radio antennas for fiberglass. They are not big enough for AM radio. What I described is bigger than their pads but still really not big enough to totally solve the problem.
Craig
Re: Radio antenna on fiberglass fender [Re: 70duster340] #1100320
10/24/11 03:19 PM
10/24/11 03:19 PM
ill
dennismopar73 Offline
ill
all you have to do is locate the antenna wire inside the car,take just the outside covering off the wire, expose the 'grounding' wire attach a wire and go to ground, problem solved!
Re: Radio antenna on fiberglass fender *DELETED* [Re: dennismopar73] #1100321
10/25/11 01:11 AM
10/25/11 01:11 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
Post deleted by DirectSubjection
Ride eternal, shiny and chrome
Re: Radio antenna on fiberglass fender [Re: DirectSubjection] #1100322
10/25/11 08:56 PM
10/25/11 08:56 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Find it hard to believe that will work. There is no electrical theory cited in the ad and I know of none that would apply. And for $50 american, I don't think I want to even try it.
Re: Radio antenna on fiberglass fender [Re: denfireguy] #1100323
10/25/11 09:49 PM
10/25/11 09:49 PM
Here
Here
Nevermind - I agree with you. The board where i found that link had someone say it worked well, but seeing this:
http://www.youtube.com/watch?v=YHpVwVOfppg
Sorry - forget it, save your money.
Re: Radio antenna on fiberglass fender [Re: DirectSubjection] #1100324
10/26/11 09:23 AM
10/26/11 09:23 AM
ill
ill
what you seen in the video is an electro magnet,,would work on some applications, but not a radio that receives a signal,
what i told him to do is his fix for no ground on fiberglass fenders,
quick easy and under dash ,never see it if done correct will work better, as with all devices , it will all ways search for the closes ground.
Re: Radio antenna on fiberglass fender [Re: dennismopar73] #1100325
10/26/11 11:02 PM
10/26/11 11:02 PM
So dennis, what you are saying is to remove the insulation from the coaxial cable inside the car where it leads to the radio, and ground that wire mesh somewhere inside the car?
Re: Radio antenna on fiberglass fender [Re: 70duster340] #1100326
10/27/11 12:03 AM
10/27/11 12:03 AM
ill
ill
yes sir , the outer 'mess' is just a ground,
Re: Radio antenna on fiberglass fender [Re: dennismopar73] #1100327
10/27/11 10:11 PM
10/27/11 10:11 PM
Well, I'll give that a shot, thanks!
