Re: aluminum radiator question
[Re: a493demon]
#1099700
10/23/11 12:23 AM
10/23/11 12:23 AM
i have a champion rad. work's good and for the price you can't beat it. brad p.s i think they have a add in race part's for sale.
I just bought one of these myself and waiting for it to arrive. Rad, shroud and fans included with the price is a tranny cooler.
[Re: superstreet1896]
#1099702
10/23/11 12:49 AM
10/23/11 12:49 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I went with a Summit 3 pass 2 core(1" cores)radiator with a HHS fan(or what ever the letters are)... this is going in my Rampage for the street/strip
#1099704
10/23/11 01:05 AM
10/23/11 01:05 AM
Posts: 2,496 PA
moparacer
PA
I have a Jegs radiator I made to direct fit a 68 Dart and it drops right in my 67 Barracuda I am working on.
All rubber mounts and isnt hard to do.
If you want I will take some pictures of it tomorrow night when I get home from the Maple grove 10K footbrake race.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
#1099705
10/23/11 01:07 AM
10/23/11 01:07 AM
MR_P_BODY
looked at the champion but i dont see a direct fit for a 67-69 A body. been looking at the summit but i need to measure the one i have to see how big it is. im looking for the easiest fit, would like to just bolt it in and off i go. im not a great fab. keep the ideas comming, thanks
Summit does offer direct replacements but for a couple of mounts the price goes UP Also the Summit brand is made by Northern Radiator which is American made
[Re: CrAzYMoPaRGuY]
#1099708
10/23/11 02:18 AM
10/23/11 02:18 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I have one of the Summit Radiators in the Satellite. Fits like a glove, and keeps up with the 452 on the street just fine. Had my buddy fab me up a custom shroud. Looks pretty good, and works great.
[Re: CrAzYMoPaRGuY]
#1099711
10/26/11 01:21 PM
10/26/11 01:21 PM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
I just bought a Champion 3 core for my Charger.... didn't have a rad and the one I bought is probably cheaper than any 26" stocker price...
Yep. They are nice and the price is right. I got mine for like 200 bucks. I am using one made for a late corvette in my dakota, and I read in I think car craft that there is a 2 speed fan from a taurus that works perfectly for it with a 100 amp alternator. I am going to give it a try with that fan.
I have no plan messing with an electric pump on the street.
[Re: 71cuda]
#1099712
10/26/11 01:29 PM
10/26/11 01:29 PM
Posts: 2,496 PA
moparacer
PA
Sorry it took me so long. Here are the pictures of the way I do a aluminum rad in an a body.
I use 90s dodge dakota lower rubber mounts in the holes that are already in the core support. I weld a 1/2 inch dowel rod on each tank and weld a flat piece on each one to set on the mounts. Then, I weld two pieces of angle at the top of each tank that line up with the holes that are already in the upper part of the core support. I stick early 90s dodge caravan rubber mounts through thee holes and draw them up with 1/4 inch bolts. When its done, the whole radiator is mounted in rubber and all it takes is two bolts up top and it comes right out..
[Re: moparacer]
#1099713
10/26/11 01:30 PM
10/26/11 01:30 PM
Posts: 2,496 PA
moparacer
PA
Holes in bottom of support.
[Re: moparacer]
#1099714
10/26/11 01:31 PM
10/26/11 01:31 PM
Posts: 2,496 PA
moparacer
PA
Holes in top of support with caravan bushing in it.
[Re: moparacer]
#1099715
10/26/11 01:32 PM
10/26/11 01:32 PM
Posts: 2,496 PA
moparacer
PA
Radiator setting in bottom hole.
[Re: moparacer]
#1099716
10/26/11 01:34 PM
10/26/11 01:34 PM
Posts: 2,496 PA
moparacer
PA
Radiator bolted in with top bracket and bushing.
[Re: moparacer]
#1099717
10/26/11 01:44 PM
10/26/11 01:44 PM
Posts: 2,496 PA
moparacer
PA
Setting in my 67 Barracuda.
