Re: roller cam bearings 50 mm small block
[Re: WHITEDART]
#1099315
10/22/11 07:24 PM
10/22/11 07:24 PM
Posts: 52,972 Romeo MI
MR_P_BODY
i just was looking at my ritter XR1 Block and it dose not have oil feeds holes to the cam bearings do those have to be drilled out for roller bearings in the past i have used stock blocks they have all had oil holes.. LOOKING FOR HELP
No, the cage doesnt have a oil hole in it... just uses splash to oil it
[Re: MR_P_BODY]
#1099316
10/22/11 07:35 PM
10/22/11 07:35 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
cool thanks guys now i can sleep at 2:night
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#1099317
10/22/11 08:03 PM
10/22/11 08:03 PM
MR_P_BODY
How are you oiling your rockers... PR
[Re: MR_P_BODY]
#1099318
10/22/11 08:15 PM
10/22/11 08:15 PM
WHITEDART
bean town ....Ca
im not shure but im thinkin through push rods but the lifter bore have not been drill for oil ethere have to get it to the shop this week
[Re: WHITEDART]
#1099319
10/22/11 08:30 PM
10/22/11 08:30 PM
MR_P_BODY
I have a fixture that drops into the lifter bore and you drill the hole through it(MP sells one) but their hole is larger... I made my .060... the lifters have a hole for the axle and the push rod oiling
[Re: WHITEDART]
#1099321
10/23/11 02:27 AM
10/23/11 02:27 AM
MR_P_BODY
do you have pic of that
Sorry ... no I dont... if I find it in the shop I'll take one
[Re: tubtar]
#1099324
10/23/11 10:54 AM
10/23/11 10:54 AM
MR_P_BODY
Something like this........ I used the M.P. fixture with a #2 center drill , then opened the holes to 3/32nds. .09375 after I got the tip of the center drill to locate and start the holes.........the holes in the fixture are .125 as I recall. .060 is all you need , but I wasn't comfortable using a bit that small with the angle and a hand drill.
Yeah I have one like that... I took that design but changed it a bit... I used a electric pin drill to drill the holes but I was just drilling the bushings
