roller cam bearings 50 mm small block #1099313
10/22/11 06:54 PM
10/22/11 06:54 PM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
i just was looking at my ritter XR1 Block and it dose not have oil feeds holes to the cam bearings do those have to be drilled out for roller bearings in the past i have used stock blocks they have all had oil holes.. LOOKING FOR HELP
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: roller cam bearings 50 mm small block [Re: WHITEDART] #1099314
10/22/11 07:23 PM
10/22/11 07:23 PM
Sterling Heights, MI
MCHBOB Offline
MCHBOB  Offline
no you dont use pressurized oil to oil the bearing
No hole
Re: roller cam bearings 50 mm small block [Re: WHITEDART] #1099315
10/22/11 07:24 PM
10/22/11 07:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No, the cage doesnt have a oil hole in it... just uses
splash to oil it
Re: roller cam bearings 50 mm small block [Re: MR_P_BODY] #1099316
10/22/11 07:35 PM
10/22/11 07:35 PM
bean town ....Ca
W
W
bean town ....Ca
cool thanks guys now i can sleep at 2:night
Re: roller cam bearings 50 mm small block [Re: WHITEDART] #1099317
10/22/11 08:03 PM
10/22/11 08:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
How are you oiling your rockers... PR
Re: roller cam bearings 50 mm small block [Re: MR_P_BODY] #1099318
10/22/11 08:15 PM
10/22/11 08:15 PM
bean town ....Ca
W
W
bean town ....Ca
im not shure but im thinkin through push rods but the lifter bore have not been drill for oil ethere have to get it to the shop this week
Re: roller cam bearings 50 mm small block [Re: WHITEDART] #1099319
10/22/11 08:30 PM
10/22/11 08:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have a fixture that drops into the lifter bore and
you drill the hole through it(MP sells one) but their
hole is larger... I made my .060... the lifters have
a hole for the axle and the push rod oiling
Re: roller cam bearings 50 mm small block [Re: MR_P_BODY] #1099320
10/23/11 02:22 AM
10/23/11 02:22 AM
bean town ....Ca
W
W
bean town ....Ca
do you have pic of that
Re: roller cam bearings 50 mm small block [Re: WHITEDART] #1099321
10/23/11 02:27 AM
10/23/11 02:27 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Sorry ... no I dont... if I find it in the shop I'll
take one
Re: roller cam bearings 50 mm small block [Re: MR_P_BODY] #1099322
10/23/11 04:13 AM
10/23/11 04:13 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Something like this........
I used the M.P. fixture with a #2 center drill , then opened the holes to 3/32nds. .09375 after I got the tip of the center drill to locate and start the holes.........the holes in the fixture are .125 as I recall.
.060 is all you need , but I wasn't comfortable using a bit that small with the angle and a hand drill.
Re: roller cam bearings 50 mm small block [Re: tubtar] #1099323
10/23/11 04:14 AM
10/23/11 04:14 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Here is the center drill
Re: roller cam bearings 50 mm small block [Re: tubtar] #1099324
10/23/11 10:54 AM
10/23/11 10:54 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah I have one like that... I took that design but
changed it a bit... I used a electric pin drill to
drill the holes but I was just drilling the bushings
