Vac advance tuning
#1099260
10/22/11 05:21 PM
10/22/11 05:21 PM
Posts: 15,894 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I have read a bunch of info on tuning vac advance.One day I am going to change the springs in my vac advance distributor, because it doesn't idle good right now with it connected. My questions is this; will disconnecting the vacuum advance on my MP elec ignition that is connected to my MP 360/300hp crate motor require that I change initial timing or idle setting? It seems like it would to me, but then I don't really know. Secondly, on my all stock '80 E58 Aspen, should it not even be connected at all? It has the same ignition, and I thought maybe this ignition with vac advance connected is more than this engine really needs.
One day I am going to be able to answer some questions instead of just asking them! Thanks. larry
Facts are stubborn things.
Re: Vac advance tuning
[Re: larrymopar360]
#1099263
10/22/11 08:30 PM
10/22/11 08:30 PM
Posts: 1,012 indiana
mcmopars
indiana
on the crate ,plug that up.set total @ 38,and let her rip
[Re: mcmopars]
#1099264
10/22/11 11:41 PM
10/22/11 11:41 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
The mechanic who installed the motor wanted to leave the vac advance disconnected, but I didn't. The idle is rough, so I know why he wanted to leave it off. I am going to disconnect it and check timing. Thanks.
