B/RB/Hemi external oil sytem pump cover? #1098817
10/21/11 09:50 PM
10/21/11 09:50 PM
Cab_Burge Offline OP
Who makes and sells the one piece aluminum oil pump cover to use with the Milidon external oiling systems? I thought it was either Mancini or Hughes, I looked at both web sites and can't find them I had placed a phone order for several of them and I wss told there on back order, that was in the spring or early summer, now I can't remember who makes and sells them
Re: B/RB/Hemi external oil sytem pump cover? [Re: Cab_Burge] #1098818
10/21/11 09:52 PM
10/21/11 09:52 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Muscle Motors
Re: B/RB/Hemi external oil sytem pump cover? [Re: Stanton] #1098819
10/22/11 10:19 AM
10/22/11 10:19 AM
tboomer Online work
tboomer  Online Work
Cab...I agree with Stanton! I have a Muscle Motors on mine!
Re: B/RB/Hemi external oil sytem pump cover? [Re: tboomer] #1098820
10/22/11 01:33 PM
10/22/11 01:33 PM
Thanks guys, I'll call them Monday morning EDITED: I looked at there web site last night and din't find the covers, I just treid calling them with no luck so I will call them on Monday Thanks again
Re: B/RB/Hemi external oil sytem pump cover? [Re: Cab_Burge] #1098821
10/22/11 02:01 PM
10/22/11 02:01 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Cab, I bought mine from Mancini, click on their site, do a [ milodon oil pump cover ] search, a number of them come up. Just choose your application.
Re: B/RB/Hemi external oil sytem pump cover? [Re: rowin4] #1098822
10/22/11 06:01 PM
10/22/11 06:01 PM
I looked at Mancini site and only saw the Miiidon two piece covers or the Milidon single piece remote oil filter covers I have several of the Milidon brand covers but I want a single piece cover with the oil filter mount on it so I don't have to worry about blowing the gasket out on the Milidon covers using a stock oil filter mount on the front of the Milidon pump cover Thanks for the recommendation
Re: B/RB/Hemi external oil sytem pump cover? [Re: Cab_Burge] #1098823
10/22/11 06:32 PM
10/22/11 06:32 PM
Sweden
Cuda_70 Offline
Cuda_70  Offline
Sweden
Re: B/RB/Hemi external oil sytem pump cover? [Re: Cuda_70] #1098824
10/22/11 06:51 PM
10/22/11 06:51 PM
Re: B/RB/Hemi external oil sytem pump cover? [Re: Cab_Burge] #1098825
10/24/11 05:15 PM
10/24/11 05:15 PM
Out of the State of Confusion
blue_stocker Offline
Hey Cab, you might try these folks as well, Eclectic Innovation's cover one of the MOPARTS members had his machinist friend design and make a few years back, nice piece and it works well too! It can be used with a std Melling-type pump or the Milodon race unit. I don't know if he's still making them but the last address for him was (Ted Hauser) Ecelectic Innovation, 4525 E. Industrial 4P, Simi Valley, Calif. 93063
Re: B/RB/Hemi external oil sytem pump cover? [Re: blue_stocker] #1098826
10/24/11 05:32 PM
10/24/11 05:32 PM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
I always used the milodon pump with a pump cover off a stock oil pump on it. The milodon pump had a -12 fitting but its in front of the pump not behind.
Re: B/RB/Hemi external oil sytem pump cover? [Re: Twin Turbo Mower] #1098827
10/24/11 07:12 PM
10/24/11 07:12 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The Milodon rotor design is more prone to cavitation than the stock design. The Milodon pump is also more prone to drainback (without a doubt there will be posters who've never had that problem!).
The billet Milodon cover solves the gasket problem but other than pretty and "billet", what are you getting for $250 that the Muscle Motors cover doesn't give you for $100 ?!?!?
Re: B/RB/Hemi external oil sytem pump cover? [Re: Stanton] #1098828
10/24/11 11:14 PM
10/24/11 11:14 PM
Mt.Vernon IL
Mt.Vernon IL
Nope never had a problem. My bearings all look new when I took my motor apart so no problem with the pump. As for the drain back my oil line goes above the pump with a 180 fitting into it so it cant drain back. I had an indy cover a few years back and had a 90 out of the back pointing up to prevent drain back as well.
