Re: bolt on hydraulic clutch kits
[Re: sshemi]
#1098594
10/21/11 09:34 PM
10/21/11 09:34 PM
Posts: 793 Utah
topbrent
Utah
[Re: sshemi]
#1098597
10/22/11 09:21 AM
10/22/11 09:21 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
i need some feedback from someone that has used one, if they are any good please.
After kicking and screaming, I finally went the totaly hydraulic route. I'll never go back. Basically two choices on the T.O. bearing: Timken and McLeod. Used both. Next time around I would go back to the Timken although their support is horrible. I got the impression that they were saying "we're really not Mopar guys, so..."
EDIT: I meant Tilton. Not Timken.
[Re: 340SHORTY]
#1098599
10/22/11 09:34 AM
10/22/11 09:34 AM
Posts: 2,128 sweden
sshemi
sweden
heres a pic of the small block 130 tooth hyd bell. these come in the 88-91 pickups with the OD833. this would be the cheapest wat to go hyd in the A body.a different front bearing retainer woul be needed for use of a normal 833. I run a OD833 in my 340 powered 81 shorty and love it..
i do not think i can find something like that here in sweden, besides i already have a blowproof bell. And if i go hyd i really want the hyd t/o bearing
[Re: sshemi]
#1098602
10/23/11 09:42 AM
10/23/11 09:42 AM
Commando1
what clutch cylinder did you use?
Master cylinder? I used a late 80's - early 90's Nissan Pathfinder. Less than 25 bucks and performs as good as a Wilwood.
Any part nr for the t/o bearing?
Go to their websites.
does anyone know the area of the piston in the t/o bearing so i can calc the needed clutch cyl area?
Don't over complicate this area. A master cylinder with a 3/4"+ bore will work.
also what is the stock mec link ratio?
The instructions for clutch pedal throw come with the units. I believe they are also on their websites.
[Re: sshemi]
#1098606
10/24/11 12:03 PM
10/24/11 12:03 PM
Commando1
is that for the large retainer bolt pattern....
I'm really not the go-to expert on this stuff. I was just sharing what I discovered through my own trial and error filled excursion into it. If I was you, I would call tech support and pick their brains.
[Re: sshemi]
#1098608
10/24/11 02:04 PM
10/24/11 02:04 PM
Posts: 2,128 sweden
sshemi
sweden
just got off the phone with keisler and they do NOT have a bearing for the a-833.
i think im gonna try the tilton 400 series anyway.
[Re: toddd]
#1098611
10/24/11 10:49 PM
10/24/11 10:49 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
American power train has what you need, just Google and click on mopar hydraulic clutch. I talked to these guy;s earlier this month about this set up, real easy to do, just a couple of measurements and bolt it up. Now the cost is not so easy for me, I'll stick to the old hardware.
