Evaporust? #1097936
10/20/11 12:07 AM
10/20/11 12:07 AM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
Where to get Evaporust?
Thanks.
Re: Evaporust? [Re: lahatte] #1097937
10/20/11 12:41 AM
10/20/11 12:41 AM
California
sixpaktoogo Offline
sixpaktoogo  Offline
California
Harbor Freight Tools
Re: Evaporust? [Re: lahatte] #1097938
10/20/11 12:55 AM
10/20/11 12:55 AM
Houston, Texas
racerx20 Offline
Standard but OK
racerx20  Offline
Standard but OK
Houston, Texas
I get it at Oreilly Auto parts.
1972 Road Runner
1988 Shelby CSX-T
Re: Evaporust? [Re: racerx20] #1097939
10/20/11 06:28 AM
10/20/11 06:28 AM
www.mmcdetroit.com
MMC Detroit Offline
MMC Detroit  Offline
www.mmcdetroit.com
It is a good product. I just used it last weekend. It is great on light surface rust.
MMC/ ICCA Detroit. The Motor City or where ever there is Mopars
Re: Evaporust? [Re: lahatte] #1097940
10/20/11 08:25 AM
10/20/11 08:25 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Tractor Supply has it
Re: Evaporust? [Re: gtx6970] #1097941
10/20/11 09:48 AM
10/20/11 09:48 AM
Cleveland, Ohio
northcoastmopar Offline
Cleveland, Ohio
Autozone
Summit Racing
Re: Evaporust? [Re: lahatte] #1097942
10/20/11 11:43 AM
10/20/11 11:43 AM
Vista, California
ChickMaggot Offline
ChickMaggot  Offline
Vista, California
Pep Boys
You can lead a gift horse to water, but you
can't look in his mouth.
Re: Evaporust? [Re: racerx20] #1097943
10/20/11 07:11 PM
10/20/11 07:11 PM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
Ok, thanks for the responses. I didn't know it was so common. It's strange, Last time I tried I couldn't find it via Google. Oh well.
Re: Evaporust? [Re: lahatte] #1097944
10/20/11 07:17 PM
10/20/11 07:17 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
http://www.rustremover.net/
Right from the source.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Evaporust? [Re: lahatte] #1097945
10/21/11 09:57 AM
10/21/11 09:57 AM
Ohio
carteravs Offline
carteravs  Offline
Ohio
Tractor Supply CO. has a product, (Sterosol Milkstone Remover and Acid
Rinse,SKU # ST11), that has the same active ingredient, (Phosphoric Acid), as all the other rust removers and is about $12.00 a gallon. One gallon allows you to make 10 gallons of cleaner. Only stores that have dairy farms in their area carry it, but I would imagine any store could order it for you.
Re: Evaporust? [Re: carteravs] #1097946
10/21/11 02:59 PM
10/21/11 02:59 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I don't think evaporust is an acid. Been awhile since I read the specifics, but I think it creates a process called chelation(?) that causes the rust molecules to attract to each other, which causes the rust to leave the host metal.
Re: Evaporust? [Re: Neil] #1097947
10/21/11 03:14 PM
10/21/11 03:14 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
you can mix your own solution that works equally as well, for 1/5th the cost. if you only need a gallon, then i guess its not really a big deal but if you want to fill up a tote bin and put some larger parts in it, search on here for rust remover. it works good, you jus thave to ber very thorough when cleaning after words.
Re: Evaporust? [Re: JAMESDART] #1097948
10/24/11 07:17 AM
10/24/11 07:17 AM
Woodbridge
Tommy The Chryco Offline
Woodbridge
whats is your solution ?
Fight the Good Fight- Elastomeric Bumpers and The Better "Shaker kits"
