first time to the track...question #1097808
10/19/11 10:41 PM
10/19/11 10:41 PM
CT
440Kilmartin Offline OP
CT
first time going down the track ran a 13.4 at 103.5 with my roadrunner 440 4 speed 4:10 d60 street car... i want to see at least 12.99 next time ....maybe nitrous?
Re: first time to the track...question [Re: 440Kilmartin] #1097809
10/19/11 10:45 PM
10/19/11 10:45 PM
Guitar Jones Offline
I'd say that's pretty good but you didn't list many specifics about it.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: first time to the track...question [Re: 440Kilmartin] #1097810
10/19/11 10:47 PM
10/19/11 10:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What was the rest of the time slip... 60', 330, 660
Re: first time to the track...question [Re: 440Kilmartin] #1097811
10/19/11 11:24 PM
10/19/11 11:24 PM
ct
jkgtx Offline
jkgtx  Offline
ct
great to see you at the track mike,thaught you would want to go faster next time lol you did a great job driving
[b] [color:"red"] 67 GTX 440 twin turbo efi 10.72 128 3900lb 3.55
Re: first time to the track...question [Re: jkgtx] #1097812
10/19/11 11:27 PM
10/19/11 11:27 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I suspect you could get close or even make that ET once you get some more seat time and really nail down driving the car constantly.
Re: first time to the track...question [Re: WILD BILL] #1097813
10/19/11 11:34 PM
10/19/11 11:34 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yes we need the rest of the combo and the rest of the timeslip. Thats a real nice looking Runner. Ron
Re: first time to the track...question [Re: 440Kilmartin] #1097814
10/19/11 11:40 PM
10/19/11 11:40 PM
CT
CT
thanks again jeff for all your help at the track.
60ft 1.93
330 5.61
660 8.65 @ 80.80mph
1000 11.25
1320 13.44 @ 103.5mph
its a stock stroke 440 60over, flat top pistons, 452 heads, 780 holley vacuum 2ndarys, torker intake, headers...nothing fancy
I'll be at one more test and tune on the 30th with a new shifter shooting for 12's
Re: first time to the track...question [Re: 440Kilmartin] #1097815
10/19/11 11:45 PM
10/19/11 11:45 PM
CT
CT
i was also told to ditch the slapper bars for an adjustble pinion snubber on a stick car?
Re: first time to the track...question [Re: 440Kilmartin] #1097816
10/19/11 11:45 PM
10/19/11 11:45 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Do you have headers on it and is the exh closed up ? Ron
Re: first time to the track...question [Re: 383man] #1097817
10/19/11 11:52 PM
10/19/11 11:52 PM
CT
CT
full 3'' exhuast, mild hydralic cam.i threw in some motor specs above
Re: first time to the track...question [Re: 440Kilmartin] #1097818
10/19/11 11:54 PM
10/19/11 11:54 PM
ct
jkgtx Offline
jkgtx  Offline
ct
hope your shifter helps and goodluck,if i can help in anyway give me a yell
Re: first time to the track...question [Re: jkgtx] #1097819
10/19/11 11:57 PM
10/19/11 11:57 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I was thinking you might pick up a few tenths real fast uncapping the headers. Ron
Re: first time to the track...question [Re: 440Kilmartin] #1097820
10/20/11 12:00 AM
10/20/11 12:00 AM
your 60 ft. times are horrible, what size and type tires did you use that day?Usually for every .10 you improve on the 60 ft. times you get anywhere from .12 to .18 decrease in the 1/4 mile ET. Hooking the car up in the first 40 ft is the key to fast time slips BTW, stick cars are a real test of the drivers skills Been there done that Keep after it, you'll get there Can you get a short pair of slicks to use like a set of 28x10x15?How good is your clutch now Can you bog the car off of the starting line with different driving styles? Sometimes that helps a bunch
Re: first time to the track...question [Re: 383man] #1097821
10/20/11 12:00 AM
10/20/11 12:00 AM
ct
jkgtx Offline
jkgtx  Offline
ct
always dropped two tenths uncorking them
Re: first time to the track...question [Re: jkgtx] #1097822
10/20/11 12:06 AM
10/20/11 12:06 AM
CT
CT
sounds like a plan with the open headers...free horsepower.
tires are 295 55 15 mickey tompson et street radials 18psi.
they spun alot until i started actually doing a burnout in the waterbox then they hooked real good and bogged the motor down..but the time got alot better
Re: first time to the track...question [Re: 440Kilmartin] #1097823
10/20/11 12:12 AM
10/20/11 12:12 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Open headers, jetting, timing , fuel pressure, tire pressure, launch and shift rpm.
Dial it in......you'll get your 12s.
Re: first time to the track...question [Re: 440Kilmartin] #1097824
10/20/11 12:15 AM
10/20/11 12:15 AM
MR_P_BODY Offline
MR_P_BODY  Offline
60ft 1.93
330 5.61
660 8.65 @ 80.80mph
1000 11.25
I see your spinning alot off the line... what tires...
that where you really need to work on
Re: first time to the track...question [Re: MR_P_BODY] #1097825
10/20/11 12:40 AM
10/20/11 12:40 AM
CT
CT
Re: first time to the track...question [Re: 440Kilmartin] #1097826
10/20/11 12:55 AM
10/20/11 12:55 AM
upstate, New York
jvcuda Offline
jvcuda  Offline
upstate, New York
Good job taking out Pat. Here's another video of you: LVDsupercarshootout
john
Re: first time to the track...question [Re: jvcuda] #1097827
10/20/11 01:01 AM
10/20/11 01:01 AM
upstate, New York
jvcuda Offline
jvcuda  Offline
upstate, New York
I almost forgot, mopar day at the valley,this saturday oct,22.
