Re: first time to the track...question
[Re: 440Kilmartin]
#1097809
10/19/11 10:45 PM
10/19/11 10:45 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
I'd say that's pretty good but you didn't list many specifics about it.
[Re: 440Kilmartin]
#1097814
10/19/11 11:40 PM
10/19/11 11:40 PM
Posts: 57 CT
440Kilmartin
CT
thanks again jeff for all your help at the track. 60ft 1.93 330 5.61 660 8.65 @ 80.80mph 1000 11.25 1320 13.44 @ 103.5mph
its a stock stroke 440 60over, flat top pistons, 452 heads, 780 holley vacuum 2ndarys, torker intake, headers...nothing fancy I'll be at one more test and tune on the 30th with a new shifter shooting for 12's
[Re: 440Kilmartin]
#1097818
10/19/11 11:54 PM
10/19/11 11:54 PM
Posts: 622 ct
jkgtx
ct
hope your shifter helps and goodluck,if i can help in anyway give me a yell
[b] [color:"red"] 67 GTX 440 twin turbo efi 10.72 128 3900lb 3.55
[Re: 440Kilmartin]
#1097820
10/20/11 12:00 AM
10/20/11 12:00 AM
Posts: 43,236 Bend,OR USA
Cab_Burge
your 60 ft. times are horrible, what size and type tires did you use that day?Usually for every .10 you improve on the 60 ft. times you get anywhere from .12 to .18 decrease in the 1/4 mile ET. Hooking the car up in the first 40 ft is the key to fast time slips BTW, stick cars are a real test of the drivers skills Been there done that Keep after it, you'll get there Can you get a short pair of slicks to use like a set of 28x10x15?How good is your clutch now Can you bog the car off of the starting line with different driving styles? Sometimes that helps a bunch
[Re: 383man]
#1097821
10/20/11 12:00 AM
10/20/11 12:00 AM
Posts: 622 ct
jkgtx
ct
always dropped two tenths uncorking them
[Re: 440Kilmartin]
#1097824
10/20/11 12:15 AM
10/20/11 12:15 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I see your spinning alot off the line... what tires... that where you really need to work on
[Re: MR_P_BODY]
#1097825
10/20/11 12:40 AM
10/20/11 12:40 AM
Posts: 57 CT
440Kilmartin
CT
