Performer RPM on a 440 under stock 69 RoadRunner hood? #1097581
10/19/11 04:24 PM
10/19/11 04:24 PM
Iowa
GreenBird Offline OP
Iowa
Hi: I ran the search function and found discussions on this general topic but did not see one directly dealing with my situation.
In my 69 Road Runner, I am going to replace my stock 383 engine with a 440. The 440 will have a Performer RPM intake and Edelbrock AVS 800cfm. I currently have a 383 fresh air intake assembly (I understand the base is taller than the 440 version). Any chance the 383 fresh air intake will fit under the standard steel, stock hood (without the fresh air box)? If not, will the 440 base or a drop base air cleaner fit? Any room for a carb spacer? Other ideas?
Any feedback on this manufacturer of fiberglass drop bases?
http://hybrid-fiberglass-solutions.com/products/custombaseplates.html
Thanks.
Re: Performer RPM on a 440 under stock 69 RoadRunner hood? [Re: GreenBird] #1097582
10/19/11 04:36 PM
10/19/11 04:36 PM
Ontario, Canada
D149 Offline
D149  Offline
Ontario, Canada
I don't know if this will help or not since I don't have an air grabber, but... I have a '69 Road Runner with a 440 and Edelbrock RPM intake, and the stock unsilenced air cleaner would definitely not fit. I had to go with an aftermarket drop air cleaner.
1968 Valiant Signet 4dr. 273 4spd
1969 Road Runner 383 4spd
1969 Barracuda 318 auto
1970 Dart Swinger 340 4spd
1975 Cordoba 400-4bbl
1988 Caravelle 318 Auto
1999 Dakota R/T
2000 Viper GTS
2001 Ram 2500 Diesel 6spd
2018 Dodge Challenger GT (Winter beater!)
Re: Performer RPM on a 440 under stock 69 RoadRunner hood? [Re: D149] #1097583
10/19/11 04:41 PM
10/19/11 04:41 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
They hybrid fiberglass guy is a board member on here and I've heard nothing but good things about his products.
Re: Performer RPM on a 440 under stock 69 RoadRunner hood? [Re: GreenBird] #1097584
10/19/11 04:46 PM
10/19/11 04:46 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Thanks.
No the 383 air cleaner base will not fit under a stock hood, same goes for a 440 base. any intake other than a factory stock height intake on it's respective base engine block will require a drop base air cleaner and depending on the height of the intake posibbly a shorter than 3" hi element. Once you get into drop base units and short air filter elements you run into the possibly of restricting air flow into the primaries because of the choke air horn height .
Re: Performer RPM on a 440 under stock 69 RoadRunner hood? [Re: GreenBird] #1097585
10/19/11 05:10 PM
10/19/11 05:10 PM
Central IL
70Sbird Offline
70Sbird  Offline
Central IL
not sure how it compares, but I had a Performer RPM on my 440 in a Superbird. Holley carb and the most "drop" drop base air cleaner I could find, then had to find an element with only about a 2" height.
This pic is the engine with the performer RPM, Holley carb, thick (about 0.2") carb gasket and the drop base air cleaner. This configuration rubbed the bottom of the stock (flat Coronet) hood, requiring me to find a thinner air filter.
Hope this helps.
Scott
Re: Performer RPM on a 440 under stock 69 RoadRunner hood? [Re: 70Sbird] #1097586
10/19/11 05:14 PM
10/19/11 05:14 PM
U.S.S.A.
U.S.S.A.
Hope this helps.
Scott
That helps well as the hood is basically at the same height as the 69RR , maybe a 1/2" shorter.
How close is the top to the carb air horn with your 2" element?
Re: Performer RPM on a 440 under stock 69 RoadRunner hood? [Re: GreenBird] #1097587
10/20/11 03:16 PM
10/20/11 03:16 PM
Iowa
Iowa
Thanks for all the help. I am going to try the fiberglass drop base -- hopefully, the hood will close and the carb will get enough air. I am still a couple of months from completing the project, and fitting and closing the hood will be the last step, but I will post how things work out.
Re: Performer RPM on a 440 under stock 69 RoadRunner hood? [Re: GreenBird] #1097588
10/21/11 12:54 PM
10/21/11 12:54 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
I would toss the performer rpm for the holley intake as it quite a bit lower solving most of you issue. My 440 runs even better with the holley intake frm low to high rpm with unreal midrange/topend power.
