Performer RPM on a 440 under stock 69 RoadRunner hood?
#1097581
10/19/11 04:24 PM
10/19/11 04:24 PM
Posts: 64 Iowa
GreenBird
Iowa
Hi: I ran the search function and found discussions on this general topic but did not see one directly dealing with my situation. In my 69 Road Runner, I am going to replace my stock 383 engine with a 440. The 440 will have a Performer RPM intake and Edelbrock AVS 800cfm. I currently have a 383 fresh air intake assembly (I understand the base is taller than the 440 version). Any chance the 383 fresh air intake will fit under the standard steel, stock hood (without the fresh air box)? If not, will the 440 base or a drop base air cleaner fit? Any room for a carb spacer? Other ideas? Any feedback on this manufacturer of fiberglass drop bases? http://hybrid-fiberglass-solutions.com/products/custombaseplates.htmlThanks.
Re: Performer RPM on a 440 under stock 69 RoadRunner hood?
[Re: GreenBird]
#1097582
10/19/11 04:36 PM
10/19/11 04:36 PM
Posts: 105 Ontario, Canada
D149
Ontario, Canada
I don't know if this will help or not since I don't have an air grabber, but... I have a '69 Road Runner with a 440 and Edelbrock RPM intake, and the stock unsilenced air cleaner would definitely not fit. I had to go with an aftermarket drop air cleaner.
1968 Valiant Signet 4dr. 273 4spd 1969 Road Runner 383 4spd 1969 Barracuda 318 auto 1970 Dart Swinger 340 4spd 1975 Cordoba 400-4bbl 1988 Caravelle 318 Auto 1999 Dakota R/T 2000 Viper GTS 2001 Ram 2500 Diesel 6spd 2018 Dodge Challenger GT (Winter beater!)
[Re: GreenBird]
#1097584
10/19/11 04:46 PM
10/19/11 04:46 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
Thanks.
No the 383 air cleaner base will not fit under a stock hood, same goes for a 440 base. any intake other than a factory stock height intake on it's respective base engine block will require a drop base air cleaner and depending on the height of the intake posibbly a shorter than 3" hi element. Once you get into drop base units and short air filter elements you run into the possibly of restricting air flow into the primaries because of the choke air horn height .
[Re: 70Sbird]
#1097586
10/19/11 05:14 PM
10/19/11 05:14 PM
JohnRR
not sure how it compares, but I had a Performer RPM on my 440 in a Superbird. Holley carb and the most "drop" drop base air cleaner I could find, then had to find an element with only about a 2" height. This pic is the engine with the performer RPM, Holley carb, thick (about 0.2") carb gasket and the drop base air cleaner. This configuration rubbed the bottom of the stock (flat Coronet) hood, requiring me to find a thinner air filter. Hope this helps. Scott
That helps well as the hood is basically at the same height as the 69RR , maybe a 1/2" shorter.
How close is the top to the carb air horn with your 2" element?
