99 Hemi Head Questions #1097182
10/18/11 07:54 PM
10/18/11 07:54 PM
Blue Ridge, VA
Plumb Wired Offline OP
Blue Ridge, VA
Excuse my ignorance once again on the 99 Hemi:
Can the two bolt rocker stand heads be converted to use the four bolt stands?
Also, will the 99 Hemi heads bolt to a KB, Indy or World aluminum block?
Thanks,
Mike Gray
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: 99 Hemi Head Questions [Re: Plumb Wired] #1097183
10/18/11 08:43 PM
10/18/11 08:43 PM
Orange County, Ca.
B1CUDA Offline
B1CUDA  Offline
Orange County, Ca.
No and no.
If you are planning on going this route, get the latest 4 bolt stand heads. The single and two bolt stand heads are cheap for a reason.
Re: 99 Hemi Head Questions [Re: B1CUDA] #1097184
10/18/11 08:59 PM
10/18/11 08:59 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
For blocks you are either stuck with the pro stock block or need to go to a billet one
Re: 99 Hemi Head Questions [Re: Diablo] #1097185
10/18/11 09:04 PM
10/18/11 09:04 PM
Blue Ridge, VA
Blue Ridge, VA
Thanks! That's what I thought on both questions, just wanted to verify.
RIP Monte Smith
aka: OutlawFish
Re: 99 Hemi Head Questions [Re: Plumb Wired] #1097186
10/18/11 09:17 PM
10/18/11 09:17 PM
Get-X Offline
Get-X  Offline
The PS engines ran the 99 stuff through 2005 into 2006. Is the new stuff better? Yes it is stiffer, That being said, the old stuff works fine when properly maintained.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: 99 Hemi Head Questions [Re: Get-X] #1097187
10/18/11 11:41 PM
10/18/11 11:41 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
what are new motors called?
Re: 99 Hemi Head Questions [Re: tjmarcus1] #1097188
10/19/11 01:30 AM
10/19/11 01:30 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
06 Hemi
FWIW you have the answers there Mike. I have been taking a crash course myself and found a couple of really good resouorces and learned alot already. I have also been poking around asking about possibilities and it seems 550" really is about the limit with these blocks, just not a lot of room there. But if you go billet...I am trying to decide what to do if the Hot Street thing goes away. If that happens I think we will be going to a power adder set up and maybe try the 8.5 class. But will see what happens.
