99 Hemi Head Questions
#1097182
10/18/11 07:54 PM
10/18/11 07:54 PM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
Excuse my ignorance once again on the 99 Hemi:
Can the two bolt rocker stand heads be converted to use the four bolt stands?
Also, will the 99 Hemi heads bolt to a KB, Indy or World aluminum block?
Thanks, Mike Gray
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
Re: 99 Hemi Head Questions
[Re: Diablo]
#1097185
10/18/11 09:04 PM
10/18/11 09:04 PM
Plumb Wired
Blue Ridge, VA
Thanks! That's what I thought on both questions, just wanted to verify.
RIP Monte Smith
[Re: Plumb Wired]
#1097186
10/18/11 09:17 PM
10/18/11 09:17 PM
Posts: 614 Michigan
Get-X
The PS engines ran the 99 stuff through 2005 into 2006. Is the new stuff better? Yes it is stiffer, That being said, the old stuff works fine when properly maintained.
'65 Belvedere '68 GTX '57 Dodge pickup
[Re: Get-X]
#1097187
10/18/11 11:41 PM
10/18/11 11:41 PM
Posts: 2,119 sc
tjmarcus1
sc
what are new motors called?
