best way to remove undercoating #109626
08/24/08 12:32 PM
08/24/08 12:32 PM
Hamilton, Ont, Canada
Dart_it_All Offline OP
What is the best way to remove the factory under coating from a fender?
I am doing this at home,(can not make to much of a mess) I do not have acess to a sandblaster. My body guy said not to use a torch or I will run the risk of warping the fender.
Father of
1969 Dart Custom, 318 4bbl, 904, 8 1/4 rear soon to be a 340
1967 Barracuda, 273 Commando, 4bbl, 904, 7 1/4 rear Project car
Re: best way to remove undercoating [Re: Dart_it_All] #109627
08/24/08 12:34 PM
08/24/08 12:34 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
PM Challenger1 he's the man at removing undercoating via some kind of pressure/steam cleaner.
Re: best way to remove undercoating [Re: Dart_it_All] #109628
08/24/08 12:46 PM
08/24/08 12:46 PM
Slidell, La.
doctor_mopar Offline
Slidell, La.
Mineral spirits may soften , and clean it off.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: best way to remove undercoating [Re: moparpollack] #109629
08/24/08 12:50 PM
08/24/08 12:50 PM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
NO QUESTION!
I got the steam clean treatment, about 2 hours and it is all gone...
I would think it has to be on a rotisserie to do it; that steam cumming back down on you would be bad
Re: best way to remove undercoating [Re: Dart_it_All] #109630
08/24/08 01:35 PM
08/24/08 01:35 PM
northeast ohio
mkdart Offline
mkdart  Offline
northeast ohio
Use a propane torch,just be careful.Did my whole car that way. Mike
Re: best way to remove undercoating [Re: mkdart] #109631
08/24/08 02:38 PM
08/24/08 02:38 PM
N. of 8mile, S. of heaven
Spike Offline
Go Blue!!
Spike  Offline
Go Blue!!
Propane torch and a putty knife. Heat it up, scrape it off. Clean any residue afterwards with a rag and some mineral spirits.
Re: best way to remove undercoating [Re: Dart_it_All] #109632
08/24/08 03:51 PM
08/24/08 03:51 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I used an electric heat gun and a scraper, so I wouldn't have open flames...
I heated up about half-foot square areas and scraped it rigt off. Prior to heating it, there was no way it would scrape off. I just took mytime and was careful. My buddy got a nasty rash from the stuff once, so try to stay clean. It's a labor intensive process, but it does come off when heated
Re: best way to remove undercoating [Re: Dart_it_All] #109633
08/24/08 03:55 PM
08/24/08 03:55 PM
west kentucky
gomangoRTSE Offline
gomangoRTSE  Offline
west kentucky
I used multiple methods, but I will tell you now for your job, go out and buy a $4.99 can of automotive stripper at Wal-Mart. Spray it on a two to three foot section, let it wrinkle, while its doing that get you some newspaper and a straight edge razor blade and holder, and/or you can also use a small scraper and simply peel it off. It may take a couple of applications and a little time, but its safe, you wont warp the fender and your mess will be minimal. I did the enitre bottom side of my car this way. Ive tried about every way at one time or another except the pressure washer thing. I think that would take some time also, not to mention alot of mess.
Re: best way to remove undercoating [Re: Dart_it_All] #109634
08/24/08 04:01 PM
08/24/08 04:01 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Hello everyone,
The best way to remove it is a steam pressure washer along with some gasoline in a pressurized sprayer. But like 6T6Cuda said, either the fender needs to be off the car or completely stripped down on a spit. I can get all the nooks and crannys, spotless.
Usally the most feasable way is with a little heat and elbow grease. If you go with heat I recomend using Map Gas in one of those trigger torches. The reason I say map gas is because it gets hotter and I can transfer the heat quickly to the undercoating and scrap it off fast before it transfers much heat the the sheet metal behind it. It just gets the job done faster than using LP gas. You have to be careful.
I would be leary of using any kind of solvent to soften it up if I was ever was gonna put a torch anywhere on the car.Hopes this helps you good luck with your car.
Check out this thread from the past. web page
Re: best way to remove undercoating [Re: Challenger 1] #109635
08/24/08 04:55 PM
08/24/08 04:55 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Like mkdart and spike says, spent one whole summer getting rid of mine. Tain't a fun job.
Re: best way to remove undercoating [Re: Cudajon] #109636
08/24/08 08:10 PM
08/24/08 08:10 PM
Great Lakes State
O
ONEBADBIRD Offline
ONEBADBIRD  Offline
O
Great Lakes State
Brake parts cleaner in the spray cans seem to soften it up. Learned this by accident though. Good Luck ,Jay
Re: best way to remove undercoating [Re: ONEBADBIRD] #109637
08/24/08 09:13 PM
08/24/08 09:13 PM
The fender is already off
I think I will go with the brake cleaner, and check out the stuff from Wall E Mart.
I know there will be a lot of elbow work to be done.
Father of
Re: best way to remove undercoating [Re: gomangoRTSE] #109638
08/24/08 09:21 PM
08/24/08 09:21 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
I don't think the brake cleaner will put much of a dent in it. I did my inner fenders with paint stripper and an engine gasket scrapper. The undercoating bubbled up and came off nicely. I cleaned it up with lacquer thinner and it looked just like new underneath.
Re: best way to remove undercoating [Re: RoadRunnerJD] #109639
08/25/08 11:08 AM
08/25/08 11:08 AM
I am gessing any product that is petrolum base will soften up the undercoating enough to scrape it off.
Father of
Re: best way to remove undercoating [Re: Dart_it_All] #109640
08/25/08 11:18 AM
08/25/08 11:18 AM
New Hampshire
W
whitemtnelf Offline
whitemtnelf  Offline
W
New Hampshire
I used Xylene, took it right off.
Re: best way to remove undercoating [Re: Dart_it_All] #109641
08/25/08 11:22 AM
08/25/08 11:22 AM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
I have found the WD-40 seems to work well also.
Re: best way to remove undercoating [Re: Cudajon] #109642
08/25/08 01:46 PM
08/25/08 01:46 PM
Cincinnati, Ohio
Cincinnati, Ohio
If you have a whole car to do, then a steam cleaner is the way to go. I did two different cars completely in one afternoon. I could never spend a whole summer on one project. Pressure washing isn't any dirtier than laying on your back with a scraper in hand.
If anyone is close to Cincy I'd consider doing it for you.
Re: best way to remove undercoating [Re: Challenger 1] #109643
08/25/08 02:03 PM
08/25/08 02:03 PM
alberta
Publicbottle Offline
alberta
I used acetone to soften it up and then scrape it of with a putty knife. then scotchbrite with some acetone for the residual and your done.
