Stopping at the end of the track.... #1095752
10/16/11 07:06 PM
10/16/11 07:06 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Well season is over for us......time to do other mods..
One of them is to have better brakes.
I started the season with a new set of caliper, rotor and pads from a 74 dart...better than the front drums I had........so I thought !
With no power brakes, I found it still very hard to get proper breaking power at the end,...you know....like having to almost stand on the pedal to get good braking.....so now I need something better.
A redbore master cylinder ? bettet pad compund ? Wilwood caliper and rotors ?
What do you have and how does it do the job ???
Dan
Re: Stopping at the end of the track.... [Re: Wedgeman] #1095753
10/16/11 07:16 PM
10/16/11 07:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you have to stand on the pedal you either have the
wrong bore master or the wrong pedal ratio
Re: Stopping at the end of the track.... [Re: MR_P_BODY] #1095754
10/16/11 07:23 PM
10/16/11 07:23 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Ok....so I take it my 67 model mc isn't good with the 74 disc set up......
I should then get a manual 74 mc ? or is there a better master cylinder ? how about the intrepid model so many talk about ?
Dan
Re: Stopping at the end of the track.... [Re: Wedgeman] #1095755
10/16/11 07:32 PM
10/16/11 07:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Dan
It all depends on how hard you are pressing on the pedal
and how hard the pedal is... a smaller bore master
will give you more pressure at the caliper but give
you a little more travel at the pedal
Re: Stopping at the end of the track.... [Re: MR_P_BODY] #1095756
10/16/11 10:00 PM
10/16/11 10:00 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
i have manual disc on my 76 duster from the factory. i had to push in a panic when a car spun out in front of me but i flatspotted all for wheels. normal stops at the end is just fine with out the feeling i need more brake power. maybe island dragway would be a better test LOL
Re: Stopping at the end of the track.... [Re: dmking] #1095757
10/16/11 10:13 PM
10/16/11 10:13 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I have 74 dart disc set up with drum rear, no problem stopping at 130 mph +. I believe I used a 1978 dodge pick up master cylinder non power disc/drum.
Re: Stopping at the end of the track.... [Re: rowin4] #1095758
10/16/11 10:20 PM
10/16/11 10:20 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Is it a track only car?Maybe you glazed the pads from the start and they did not break in properly
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Stopping at the end of the track.... [Re: rowin4] #1095759
10/16/11 10:48 PM
10/16/11 10:48 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
we have a short end of track.....
Re: Stopping at the end of the track.... [Re: Wedgeman] #1095760
10/17/11 12:41 AM
10/17/11 12:41 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Had 10" drums on the front of my A body w/440,B-body 10" drums in the rear.Car would stop "OK" but I switched to Wilwood HD brakes on the front along with the Mopar M/Cyl that Rick Ehrenberg sells and I stop MUCH better.
Nautilus Racing-
Re: Stopping at the end of the track.... [Re: Chris2581] #1095761
10/17/11 08:01 PM
10/17/11 08:01 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Chris,
do you have a part number of the Wilwood stuff ?
How can I reach Rick ?
Dan
Re: Stopping at the end of the track.... [Re: Wedgeman] #1095762
10/17/11 08:09 PM
10/17/11 08:09 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
140-2723 is the Wilwood kit I used. I got it from Hot Rods USA.
Rick is a member here,just go to "user list" right below the advertisment bar above this page and you can e-mail or PM him.
I did not use a aftermarket adjustable prop valve,just bolted the brakes and the M/Cyl up and it worked great.The rest of the OEM Mopar stuff is still on the car,along with a line lock.
Nautilus Racing-
Re: Stopping at the end of the track.... [Re: Wedgeman] #1095763
10/17/11 10:28 PM
10/17/11 10:28 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
The disc setup takes a different m/c than drum. The factory m/c is a lot bigger than your old drum one.
Time to upgrade.
Re: Stopping at the end of the track.... [Re: slantzilla] #1095764
10/17/11 11:56 PM
10/17/11 11:56 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I switched over from 11" rear drums and 10" front drums to Strange 4 piston calipers on all four corners in 2008. Some of the best money I have EVER spent on my race car. If I remember correctly, it cost about $1000-$1100 for the front and rear kits and another $200-$300 for M/C and fittings and braided SS lines, but I've not had one minute of problems since, and the car stops easily. At Clay City, Ky I ran the 1/4 mile and still was able to turn off at the 1st turn off, after running 127 mph.
Brian Dunnigan
Re: Stopping at the end of the track.... [Re: '72CudaRacer] #1095765
10/18/11 09:07 PM
10/18/11 09:07 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Cool !!
1100 $ for the four corners is a good deal to me ! Same company as strange axles ?
Do you have part numbers of the stuff you have ?
Dan
Re: Stopping at the end of the track.... [Re: Wedgeman] #1095766
10/18/11 10:11 PM
10/18/11 10:11 PM
hemi-itis Offline
hemi-itis  Offline
The way I understand,it adds up to $23 to $2400
Re: Stopping at the end of the track.... [Re: hemi-itis] #1095767
10/18/11 10:31 PM
10/18/11 10:31 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
687$ front + 582 $ for the rear
a total of 1169$ total....pretty cool !
Ny special Master cyl ?
Re: Stopping at the end of the track.... [Re: Wedgeman] #1095768
10/18/11 10:49 PM
10/18/11 10:49 PM
hemi-itis Offline
hemi-itis  Offline
That sounds too inexpensive to be strange Great deal!
Re: Stopping at the end of the track.... [Re: hemi-itis] #1095769
10/18/11 11:36 PM
10/18/11 11:36 PM
Mooresburg, Tn
Mooresburg, Tn
Wedgeman is correct on the price. I got mine in may 2008, so its a little higher now. The fronts come with an alum hub, bearings, seals, calipers, pads, brackets, bolts, shims, long studs, everything is included except the fluid.
The rears are the same except no hubs or bearings. Just be aware that you must use non- adjustable wheel bearing and my stock Dana axles would have needed the center pilot turned down to fit, but I put in strange axles and 5/8" studs at the same time.
I felt like it was a lot of bang for my buck, saved approx 50 lbs of weight and ended my brake troubles.
The part numbers I used were B1704WC rear and B4158WC front.
The biggest feature I liked over Wilwoods is Strange's hat and rotor is 1 piece steel, whereas Wilwoods had a alum hat and a bolt on steel rotor. the strange hat is about 1/4 the thickness of Wilwoods.
Also, I bought mine directly from Strange and they shipped them that day.
Hope this helps,
Brian Dunnigan
Re: Stopping at the end of the track.... [Re: Chris2581] #1095770
10/19/11 09:25 AM
10/19/11 09:25 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Not sure how fast you're going but I'm running late model A-body front disc (manual). I have the big Master w/ the much larger reservoir. I'm also using the Wilwood style adjustable PV. Seems to work fine at 119 or so.
Coming soon!!!!
Re: Stopping at the end of the track.... [Re: Mr.Yuck] #1095771
10/19/11 10:55 AM
10/19/11 10:55 AM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
Well my progression was from stock drum brakes to factory front disc brakes. WOW! The factory disc stuff is HEAVY. I still remember grabbing the parts off the edge of the tailgate of the guy I bought the brakes from, and about ripped my arms off from the weight.
After 1 season of that, I also bought the Strange front disc brakes. Really nice, and I think I save at least 50 lbs from the stock disc brake stuff.
With what you pay for used factory disc parts and the time and effort to get them set up, you are far better off just getting the Strange brakes.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
